Well my worst fears are confirmed, 3 of 3 coil packs I pulled out had cracks and tested at the 20k ohms setting 1.5,1.6 and 1.7, I have allready found some new ones at Kudos motorsport, has anyone bought from them and these are OEM units.
So what are they meant to measure? I had a quick look at the link provided but nothing stood out, it was only a quick look. :rofl:
With regards to the BKR7E group buy, I'll see what I can sort out but it will have to be after wednesday when I start looking. ;)
0.9 according to 3lit3 32's post (#71 in this thread), I got the OEM items from Bigsully84 (Kudos Motorsport http://www.kudosmotorsports.com/ ) 6 for $650, car runs stronger and smoother now, I considered taping them up, but that is a short term fix and i would of bought new ones anway, I also got some clear side indicators as well ( Im a sucker for something I want) $75. I went with the clear over the smoky look.
Iv just taken my plugs out and found they are "PFR6A-11" which at the start of thred says they are good for RB25NEO and Rb20/26 but not RB25DET??
Im having a miss firing prob under 12psi(no prob ta 10) so tryin to re-gap them, but founf that according that my conversion(online- mm inot inches, only tool for this i have) is gaped at .6!
is this any good for RB25? would a to small gap cause this prob??? Iv already had a go at silicone my coils(S1 33) ad have safc 2 installed... any thought gents??
I don't think there would be a problem the neo is similar to the R33 RB25...
On a side note I run
NGK BCPR6ES in RB25's gaped at 0.8 mm
However, I am currently running iridiums due to laziness, these are gapped to the 1.1 standard and I am running 10psi with no problems...coils are stock and are in good condition obviously...
yeah i cleaned them till they could be cleaned no more, didnt miss as much but still one big one at bout 5k, and i checked my coils so i dont think its them... thinkin maybe the safc isnt tuned for 12psi and maybe goin r&r???
ohwell, off to the shop for their opion i guess
*opens wallet and moth flies out* :
  • 4 weeks later...
would using the wrong heat range damage anything? ....i am so confused after reading all this stuff :D
i have been running PFR5G-11 plugs, but now i;'m having problems after putting on an intercooler and upping the boost to around 11psi...... missfiring under load about 5000rpm.
so i was going to give the NGK BKR7E copper plugs a go ;)
or ab i better off using BCPR6ES? i thought the copper would be worth a go first cause they are cheaper...
ohhhh, all these spark plug threads are so confusing :(
The reason of misfire is because you got -11 plugs. Ie 1.1mm gaps which is way too large. I would close the gap with a feeler gauge down to 0.8mm and reinstall. Your misfire should be gone :D Failing that, then try some new plugs. BKR7E. Iridiums are a waste of money IMO.
The more your ignition is retarded the high the cylinder pressures, which means it is harder for the spark plug to ionise the gap. When your pushing the standard ECU to 12psi as some people would say you are in the R & R mapping. What is actually happening is that you have reached a higher load cell within the timing and fuel maps that is overly rich and overly retard which makes it a shite load harder for the plug to fire. Turn the boost down!!!
There are so many reasons for miss fires and most of them is due to poor maintenance.
I ended up getting BCPR6ES plugs .... i could not get BKR7E, only BKR6E was in stock....but aparently they are different, the thread lengths are different. NGK recomends a replacement plug for the PFR5G-11, BCPR5ES. so instead i got the "6" heat range (BCPR6ES) gapped 0.8. i will give these ones a go anyway. if they fail still, i will try something else, but as i'm reading through all these suggestions in the tread, it seems anything is worth a shot, cause everyone is saying different things :D
i found 7's are better in my car
honestly does everyone think iridiums are overated and lose power and gain pinging ???
Nope. In my line I'm current running a 6 rated Iridium IX NGKs....my FTO runs IRIWAY7s as the highest u can go in the NGK range in IRRIDUM IX series is 6s. The 6s are gapped to 0.8 anf the IRIWAY7s are 0.6. I have found both to perform really well. However I might need some 7s now due to some good mods on my R33.
u can get 6 x Iridium IXs from Kudos for 99 delivered...good price. I got my IRIWAYs of Kudos also as these are not a common range stocked in australia.
Edited by khunjeng
Was thinking too.... as this seems to be such a confusing subject, could someone who knows what they are talking about please make a sticky post of what to use? they first post in this thread doesn't seem to make sence. (i.e PFR5G-11 is a platnum plug) That info could just give someone the wrong idea...
the 6 heatrange will be fine. 0.8mm is also ok. nothing will be damaged. >_<
can I just say $650 for used stock coils!!! damn. If anyone needs another set you can have my stock coil for $400.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
