  • 5 years later...
  • Replies 97
Posted Images
Hey guys. I heard there was a GTR at the drags on the weekend that did a 10.6 or something. Who was it?? XRATED?
Does anyone know how Matt is going with his Blue 32 GTR???
reply is a bit late... but yeeeer, that was mee... ha ha ha- ah the good old days. :nyaanyaa:
https://www.sau.com.au/forums/topic/104763-10-sec-gtr/#findComment-5917166
drunken thread dig of the decade!
Yep.. ha ha ah, just kind of stumbled over it. :cheers:
Think it was just under 400kw and possibly had a gearset but cant remember as that was a long long time ago......
Whats new with XRATED....?
396rwkw and a ppg dogbox- ooh and a lill hit of gas.
Nothing yet... the damn gts-t is taking up all my time atm. I'll be striping xrated down in september.
Cheers
Justin
Edited by XRATED
https://www.sau.com.au/forums/topic/104763-10-sec-gtr/#findComment-5918191
i think i have a pic from 06 at the drags if i remember correct i think it was the day you did a 10 ill try & find it thumbsup.gif
I tried to post up some pic's last night, but I can't seem to upload anything atm...\
On another note, if anyone has any pic or vid's please post em up. I lost a large chunk of my old footage and pic's on a stolen laptop years ago.
Cheers
Justin
https://www.sau.com.au/forums/topic/104763-10-sec-gtr/#findComment-5921865
