Guys,
For the people at the December club dinner will remember that I have ordered a FPV BF Typhoon, well I got it today.
For the people who do not know this car, it is a 270kw, 6 speed ZF Auto and HUGE brembo brakes.
Stock its good for a 13.2 1/4 and is one hell of a drive.
The build quality is much better than my previous XR6Turbo, so overall I am estatic with the new car.
Here are some pics.
https://www.sau.com.au/forums/topic/105080-fpv-f6-typhoon/
The car is 1800kg wet.
I have owned 22 manuals and 2 autos.
I could have got a manual, but the 6sp ZF Auto is a unbelievable gearbox. It is like no other auto I have ever driven. My XR6T was a manual and while it was fun, it did not suite the Turbo motor as it dumped boost each gearchange, where the auto just keeps pulling all the way.
As for the 13.2, there have been several stock BF F6's that have run this time with everything totally stock. Once the motor free's up they may be good for a flat 13, if you stall it up. I also think it would break into the 12's with drag radials.
I do not know why Wheels and Motor cannot get good times, but it may have to do with the fact they tested it on a 40deg c day and as we all know turbos do not like hot days.
https://www.sau.com.au/forums/topic/105080-fpv-f6-typhoon/#findComment-1934752
yeah yeah, it's real nice and all but where is the pic with the cloud of smoke pouring off the rear tyres??? geez. surely it's ready for some 'testing' now!!! haha. c'mon mal, pull your finger out!! lol
good to see it arrive though. I have to say i really quite like the interior. be sure to bring it to the next dinner. :) and the next track day!
https://www.sau.com.au/forums/topic/105080-fpv-f6-typhoon/#findComment-1934838
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
