your best options would be the pfc, dont waste you time with anything else!!!!!!!!
steve
Cost would be a factor.
AP engineering Power FC ( required for an RB20 ) would be around $1300-$1400 plus tuning of $450 ish.
Remap including supplying the necessary board hardware is around $880 all up including tune.
Any retuning is based on an hourly rate same as tuning any computer and both Lucas's Bikiroms and Glenn's Lumpyroms have had considerable success in high power applications .
Lee Sampsons 470 rwhp SR20 DET and 11.18 1/4 mile on a Lumpy rom is testament to that.
Or Adam Trewhellas RB25 Cefiro with 365 rwhp and stays on the rev limiter for most of the Wanners drift track.
Only down side is in WA you are limited to the 2 shops above as Denver mentioned so if you hate us both , your in trouble for retunes :P
Cheers
Ken
spoke to hyperdrive about it.... sounds pretty good. only downside i guess is cost of reprogramming when upgrading components.
didnt really want to spend 2k on pfc .
does 300hp@ wheels sound a bit far fetched? (already have gt2530 and gtr injectors)
Cost of retuning is no different than any other computer. Rate is $140ph on the dyno and takes about the same time as tuning an Autronic/motec/wolf/power FC.
300rwhp is achievable , I have 290rwhp in an RB20 with low mount and external gate.
( Well I did till the turbo blew on Saturday night :) )
Cheers
Ken
One of our custom made hiflo ones using a stock R33 GTS-T turbo.
No mods to be needed and dump bolts straight up. $1600 which sounds expensive except every other turbo avaliable requires dump/intake or water line changes.
We weld the gate up and run external gate mounted on a stock manifold.
Relatively cheap but a little laggy atm until we sort of few other things out.
And yes , it is on stock internals and running 16-17psi.
Cheers
Ken
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
