Trying to get a heap of Skylines out to Wed nite test tune 1st March-plenty of warning for all those interested. It would be good to have a heap of Skylines grudge racing out there. could meet at BP Wacol first and have a gentle drive up to willowbank and then hit the strip in force. Love to see side by side Liners going down the strip all nite :lol:
Who is keen????
I'll chuck in some C16 and have a few runs in anger.
I'll even chuck in some prizes for Skyline lite of the nite(best reaction) and most consistant(closest ET's over all runs)maybe Razo gear knob and Greddy oil cap :P
Edited by overev1
https://www.sau.com.au/forums/topic/105711-gtrsgtsts-to-test-tune/
Coming from the goldcoast ud be meeting at the goodna bp.
it is located:
as u come off the logan motorway and onto the ipswich motorway its on ur left about 1k up the road. take the left ater u go up the hill and over the little bridge (train station directly opposite bp)
LOL unfortunatlly RACQ dont go to willowbank for free km;s....
I got towed from the strip 2 years ago after smashing a uni joint... I had Silver membership with 40km for free and when i called they said there are no free km's from willowbank...
So i said i was out the front of willowbank and i me and mates pushed the car out the front past the gates...
When the tow truck driver got there he laughed as we went to the extra effort to get it for free.... In the end i did get free km's but it was touch and go....
BTW ill try to be ready for it... Im waiting on some adjustable caster rods to take the rear camber in a bit before drag racing... Otherwise id wheel spin all the way to 1/8th track....
Ok special deal here....I would like to come out to the test and tune night on the 1st but my g/box is almost cactus so I need it to last until I can gather a grand or so. Is there anyone who would be willing to pick me up and drop me off and I will be able to bring out the consult and some gear. That way you will be able to record your run and later view it to see any points that need adjusting or just a general view on WOT goings on. I can also assist people in changing parts if needed or mechanical advice on the night......anyone?
BTW I live in Capalaba
Edited by 3lit3 32
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
