I'd like to think the R33 GTST does it in 6 secs though I think 7 is more like it (based on experience in other cars where reliable times are available). I know import magazine did it in 6.2 or 6.3 though I don't know how reliable their figures are.
Motor magazine time the R33 GTR at 5.65 to 100. They had a passenger and a full tank of fuel. They thought that it could be reduced by another half second if they were close to empty.
Edited by Smurf
0-100km/h quoted times depend on so many factors, which is why I only gave ballpark figures. Quoting the times from one magazine means SFA - there is no guarentee that on that day in those conditions they acheived the best the car is capable of.
Also, a seat of the pants experience is not quantifiably comparable, as so much of how quick a car feels depends on the power delivery and torque curve, rather than peak power and outright acceleration. A car with a very flat torque curve from idle to redline might feel slower than an equally quick turbo car with a huge mid range surge of torque that pins you into your seat.
For your Motor reference, remember that a few years back at PCOTY Motor clocked the Bentley Contineltal GT at over 6 seconds for 0-100km/h. Does this mean that this is the best the AWD 411kw Bentley is capable of? No.
So I stand by my previous ballpark figures.
I agree that quoting one magazines time is no indication of what the car can necessarily do though it is what it did do on that day. So it is capable of what I have quoted. I have never seen any other reliable source provide a figure.
You are right in that a seat of the pants feel is not necessarily accurate. The cars that I compare it to have flatter torque curves than the Skyline and feel very similar in speed. Given that these cars in numerous other tests do it in around 6.8 seconds and using what you have said above, this would indicate that these cars are slightly faster than the GTS25T.
Don't get me wrong, I would like to think the GTS25T can do it in around 6secs (as I own one), I just don't think they can. Maybe I just own a slow one or I can't drive.
im guessing that the figures mentioned for the gtr are with dumping the clutch at 7K rpm. I think if you had to be nice to the car the r33 gtr would be in the low 6s when stock. This is also what autospeed found. The gts25t would be easily in the 7s (its not a quick car when stock).
well paul has done 0-100km/h in 4.88 seconds with maybe 180-190rwkw in a 33 GTS-t...so id say a GTR with more power and 4wd can beat that
Didnt really answer his question the key word here was stock. There are so many factors involded in times and remember when they are tested they use professional drivers and the give the car its all.
5 flat with a 7k clutch dump, maybe even just under with a decent clutch and sticky tyres.
gtst probably under 7 but not by much
I easily managed to do 0-100 in 6.5sec in my totally stock standard '98 R33 GTS25t (other than wheels/springs)....I didn't do a tyre/clutch frying launch either.
This was measured with a Greddy turbo timer in 0-100km/h attack mode (it's hooked up to ecu speed sensor).
So I definitely believe they're capable of low 6's in standard trim...
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
