  • Replies 71
Posted Images
sorry to hijak your thread mate,
how much would an apexi pfc cost? new and second hand?
and a nice fmic, is it worth paying 1k for a good one, or a shitty china cooler for like 300 :(
PFC brand new with hand controller can be found new for under $1000.
http://www.skylinesaustralia.com/forums/in...howtopic=116688
2nd hnd, id say around $700ish if u can find one....
shitty china cooler?? i know of several people using the generic 'hybrid copy' cooler and running 20+ psi on motors with 350rwhp+
these coolers can be found in complete kit with with piping for $400.
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2241809
Depends on your luck. Some of the copies from china are of pretty good quality. Not 100% exact to the original thing, but about 90%. So it depends on who manufactures them in china. Best to ask around and see which sellers sell the better ones. Bang for buck. =D
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2242830
i am thinking of acutally fitting it myself, says it has step by step instructions. has anyone done it, if so tell us whats it like. oh i have a feeling the my horn might get in the way of the intercooler (post pics when i can). saves me 400 to 500 bucks.
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2287078
I had to move my horn to fit the FMIC, i think thats just the norm.
speaking of the "shitty" chinese parts, has anyone tried one of the rediculously cheap turbos? I wanna know how long they would last. I have seen turbo plus high mount manifold for $900!
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2288001
There are threads everywhere on them. Probably wont make boost, and youll be up for a rebuild after 0.5kms.
Also wouldnt bother with the manifolds, quite a few people i know have cracked them. Even a mate who forked out to ceramic coat his cracked it.
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2288239
I will have to have a look how the horn was changed and get back to you, i didnt do it my self.
I have seen plenty of posts with people saying these turbos most likely wil be useless, but i havent actuall heard from anyone who has installed one and driven/blown it. Sounds like you have some hard evidence on the shit factor of the manifolds though.
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2288475
do the piping first then line up where the cooler would sit
then put some bricks underneath it and then connect the other side of the piping so make sure it all lines up before you drill holes for the two brackets underneath
to mount it to the top, i made a plate which goes from one bolt to the other and then a little bracket which goes to the bolt which is near the bonnet latch and the plate holds it all in place
with regards to trimming the fan, i found that i didnt need to, the piping which goes inbetween the motor and fan i got it mounted tightly closer to the engine bay and it misses the fan, although i have heard of people letting their piping hit the fan and it will trim itself evenly, saves yourself trimming it unevenly.. but dont quote me there cause mine doesnt hit :cool:
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2289680
i found that i had to take my BOV off (getting a new one anyways) and there is no other place i can put it. so just block off the vacume hose till then. what about your horn man, i ended up taking mine off. still havnt finished but i am doing ok.
https://www.sau.com.au/forums/topic/106499-turbo/page/3/#findComment-2289717
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
