Hello
I am new to this forum site.I would like to know what is the highest HP at the Rear Wheels produced by an Rb25 motor.
I currently have a GTST skyline and with the standard Rb25 motor and pumping out 498 Hp on 18 PSI.It is a manual skyline.I am running a Standard Motor,GT3540 turbo,Custom plenium,750cc Injectors,Hydra Computer,125 mm thick cooler with HKS style end tanks,3 " intercooler pipes, 3 "exhaust,Aftermarket coil packs.The engine has been run on the dyno about 150 times checking things and testing as i am trying to prove what the standard rb25 motor is capable of.
I am wanting to see who has made more hp.A dyno sheet is available and the dyno is on my own Dyno Dynamics Dyno running shootout mode.Intake Temps on the dyno sheet are 34 degrees and the room temp is 30 degrees.
Thanks
PS this is on Opitimax fuel.
Edited by LNEMUP498HP
https://www.sau.com.au/forums/topic/106775-max-hp-out-of-standard-rb25/
Yeah buddy
im going to be using this car for drifting and drag.
Its my business vehicle.I own Wild 1 Motorsport along with my Father.The vehicle is going to get rego next week as while i was building it i ran out and yeah i will be driving it.
Yeah completely standard. I Have got another motor i am building with h beam rods, Forged pistons,ARP main,conrod,Head stud kit,Cometic head gasket,Tommie cams and springs which i will be dropping into the car as soon as something goes wrong with this one.I thought i will prove ppl wrong about the standard motor.
498hp on std rb25...mate that is impressive. Now we just gotta wait for someone to come along and say 'thats a load of the "proverbial"'
What sort of knock you getting on your current tune?
  • Like 1
i am going to put the new knock sensor on tomorrow.The old one would detect to many vibrations for the engine on idle.
When i used the stithoscope or however you spell it.The knocks were very minimal.I am going to using c16 in it and see the power difference.
As for the Dyno graph I will do it with Hp And Boost to shut ever one who doubts it up.
If no 1 believes its standard. They can pay me to pull the motor out and if it is they can pay me if it isnt i will pay them.
No 1 should Doubt the POWER OF a NISSAN RB motors.
Nice work on the power figure :D
GT35's tend to make power well.
I dont think standard means much at this stage...
Make it last 12 months with SOLID work... and make sure you post backup if its still running as thats the real test, one that no-one has passed.
No winding down the boost either :O
You so adamant about "shutting people up" what are you trying to prove?
Anyone can run big power in a stock motor. A few power on the dyno runs doesnt impress anyone but the 15yr old kids :D
I saw 500rwkw+ from an internally stock RB26.
Needless to say it lasted not very long at all and died a dismal death
LOL
turn the boost down
the boost isnt going anywhere.
as for the motor
if it blows ahh well
i got my back up motor waiting.I wanna push the engine to its limit
runing just under 18 psi wont hurt the engine the head gasket is the only thing i see wreaking and the engine is reving to 7500
i will keep every one posted on how the engine goes and lasts.
You still have a little way to go, I have seen 550 rwhp out of a ZeniTani built R25DET (standard internals) using a hi mount T78. But like all RB25's with more than 320 rwkw, it didn't last very long.
It's not about "how much" power, but for "how long" it makes that power.
I have a question;
Hydra Computer
What ECU is that?
;) cheers :)
Edited by Sydneykid
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
