hmmmmmm,ive just read this thread from start to finish
some....well how can i say......interesting claims have been made
but so be it .
i personaly am not a fan of unforged handgrenade[highly researched] motors but each to there own.
and well done on your um research
i dont know why people doubt the engine
it has run the times and mph
lets see what its capable after i have done the cage and return to the drags apart from that i aint posting no more in this thread waste of time
too many people who dont respect things and other peoples reasearch
But the thing is can it do it for 12 months or more?
Thats what determines reliable in my book. Putting solid KM's on a motor
I ran around 330-350rwkw through a built RB25 with laods of dyno runs and 1/4 passes and many km's on the street, and i learnt a lot doing so.
Hence seeing the stock motor inspected for stress after more than a few months etc will be interesting.
12-18months will be the test in my book
well a lot of people dont think you've done any research, and this is why they doubt it and or ignore you. also a lot of people value their engines and don't have unlimited money so they would prefer peice of mind over saving for the cost of a set of forged pistons and proper internals vs running the stockers on the the borderline of catastrophic failure
I ran around 330-350rwkw through a built RB25 with laods of dyno runs and 1/4 passes, and i learnt a lot doing so.
if you want me to test this then i will
i wont boost it anymore or anymore nos to see how long it last
im more then happy to do so as its making more then enough power as it is and im still having fun
just have to put the other motor on a crate.
its lasted a total of 6 month 1 week so far
its only been listed on the forums for 4 months or so
i also dont drive the car like a grandma it cops more punishment then anything and any car i know.
very true i fell the same but i thought ill give this a try and its working pretty damn fine ive got my race motor at the shop ready if anything does happen as i have stated many times in this post,but as many people thought it wouldnt and would blow up straight away it hasnt.
im very impressed in the motor and how much it has handled.I wouldnt mind seeing a low 10 as the car is able to do it.ill post more as i go on the times i am running and when it blows picts of the internals.
There are two 240sx's in the US that are making 500+ whp on stock RB25 motors. One is a neo motor and the other is a series II motor.
The Neo motor dynoed 587 whp without opening the motor up. It has a custom intake and turbo manifold. He ran an 11.1 his first time out.
The other 240 has ran consistent 10's on stock motor.
Then he put a headgaster/studs and cams on and is now in the 9's. Last I heard his tranny broke and he is now running a powerglide tranny.
The US dyno readings compared to our dynos are somewhat "higher"... not the best of example, but i guess one none the less
they are a lot higher than our ausie dyno readings.. lol damn yanks trying to show off
Very interesting
but there not skylines.i could put this motor in a gemini and run mid 9`z now couldnt I
power to weight ratio is a big difference
but interesting to see some1 makeing power out of this motors
I dont know wy ppl are riding him. The fact is he has enough bolt ons for this thing, its no surprise it makes the numbers.
On a std engine is surprising, but think about the duration in which the engine is under load and i suspect many engines can handle hits for short durations...when they will catch up with this motor? Well it can only be a matter of time until its bottom end lets go, maybe not a piston or rod...but surely a bearing as the thing is still running std oiling sytstem. Will it be another 6 months, 6 days? Isnt that what he is tryign to find out?
Anyway, best of luck with it, i just wish some bloke would do this with a RB20. Its funny years ago anymore then 230rwkws and ppl thought RB25s needed pistons. Then it was 250. Now in NSW there are a few cars gettign around with 300-330rwkws so perhaps with better turbo setups and tuning these numbers are more realistic.
LOL...that said do a flat knacker 8 laps at EC and i bet the engine will give up:)
You guys are all dyno freaks, who gives a shit about dyno figures. The ET and MPH tell the story.
For me that is the key aspect of the whole debate. Outright power is one thing. Durability at whatever power the car develops is quite another. Protracted high speeds or loading WILL expose weaknesses.
Who wants bent rods / broken pistons / valve train issues / oil starvation / heat management problems because the owner/builder skimps on the build? Best long-standing advice is to run what you can afford to break.
It's not like he's suggested that he built it for circuit work. It's obviously a drag car. Don't criticise it for not being a capable circuit/drift/burnout car when nothing of the sort has been claimed.
Wake up to yourselves.
Adrian
very interesting thread....
i believe jason and his high power claims and 10second 1/4 times...
.... however i do feel your a bit agressive mate. if some one is a smartarse or anything like that, i believe you should let it slide and keep your focus on ppl who are supporting you. as hard as it is to practice what i preach.
my 2c. cheers. james.
ps. well done on your work ;)
Maybe your dyno readings are all low AND Incorrect. Ever thought about that?
Amen.
Adrian
The point of the comment was not to be critical of a drag machine - moreso to voice an opinion on the financial risk that comes with a high-stress / short-duration drivetrain used in anything other than that environment.
Best of luck to him and enjoy, I reckon. That's what modifying cars should be about.
FWIW, the best advice is still to run what you can afford to break.
cheers
Edited by Dale FZ1
Yeh but nah :D
He hasnt built anything, its a std engine. So who cares if it lets go. Even if its a catastrophic failure and rods go through the block, and the head gets damaged etc, it wont add a great deal to the cost of a fully built engine...say 6.5k instead of 6k?!?!?!
...i agree with the statement run what you can afford to break...but its a std engine..so doesnt owe him anything, it came with the car.
Its just liek the 400rwkws street GTRs, how often will any of these cars actually see full boost on the street. I suspect they are less stressed then std motors that have more mid torque and ramp onto boost more regularly on the street. Take it to a track and fang it hard for 10mins and it will be a different story...but you tweak your car to best suit what you do with it...
Just a quick question, you say you have a gt3540 - just wondering what specs as mine has the 0.82 rear and is making 480rwhp with slight compressor surge (meaning the turbo has run out of flow) and 24psi, mine also sees full boost early 4000rpms - just after a comparison with when yours sees full boost as im assuming you have a 1.06 exhaust
And congrats on the power and qtr time
Edited by turbo87
thanks mate
im running a 1.06 rear housing
and 18 psi of boost
the car is a street car and is going to be continued driving on the road once the cage is in it
i havent driven it in 2 weeks due to ecu upgrade and cage.
like i said ive got my other motor waiting there and will put that in when this blows up but it wont
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
