the standard front bar is different from the type m moddle but this would be easy changed as well. the only real way you can tell is from the bigger brakes.
Rezz: im pretty sure that most r32s come with the four pot fronts and twins rear. the GTS had smaller the GTS-t had fours and the type m has slightly larger rotors but the same size caliper. GTR caliper is bigger again.
There's nothing unique about the Type M other than the sticker on the back.
You take an R32 GTSt, it has optional upgrades available when you buy it new from the showroom, like a sports bumper, sideskirts, bigger brakes, alloy wheels etc.
You take these optional upgrades, then bundle em into a package, and offer it to customers for slightly less than what it'd cost to get em all seperately.
Now you're gonna need a name for this package... and you can't call it "OMGWTFLOL" coz no one wants to drive an "R32 GTSt OMGWTFLOL", so you call it something sporty... you call it a "Type M"... so generations of people who consequently buy the cars run around thinking they have some special car called the "R32 GTSt Type M" when all they have is a base model with a handful of factory extras... all of which are available on the base model.
You also get to sit back and chuckle in amusement as the occasional village idiot then starts calling his "R32 GTSt Type M" a "M Spec R32 GTSt".
/end rant
  • Like 1
how many r32's came with ABS?
R32 GTS4's and GTR's came standard with em, unless you requested not to get it from the factory. All the others had em optional after late 1989.
No, the car in your avatar has the 'standard' front bumper and that particular front bumper was standard across the entire range of R32s (except GT-R). There was an 'aero bumper' which could be ordered alone or as a kit as in the picture below:
^^^ This bumper was OPTIONAL. It's called the 'aero bumper'.
No, the GTS-t (base model turbo) had 2-pot front brake calipers similar (maybe the same?) to the GTS N/A versions. I don't know the diameter of the disks as I've only ever seen one GTS-t (not Type M) in the last 6 years... ALL other R32 turbos I've seen have been Type Ms.
Ok, you're right saying most R32s came with 4-pot bakes, simply because most R32s imported into Australia have been Type Ms! Trust me on this, I lived in Japan for a long time and questioned many local Japanese people about this very subject over the years.
And the EXACT same car as the GTS-t Type M minus turbo is the GTS Type J
and I belive there was a 3rd bumper style for GTS's as I own it.
GTS Type S is the coupe.
Type G and Type J were sedans I think. I should scan and translate those sales brochures one of these days...
plus they only did type M from '91 onwards the normal gts-t was 89 - 90 although a type m was available.
that sentence doesn't make sense mate. if they only made Type M from 91 onward then how can you own one? how can I own one for that matter? Mine is a 90 model and pretty sure I've seen 89 model type Ms too.
Hello,
*im logged in on my mates account, so if this is a stupid question apologies to him*
Would a R33 Type M have these same differences?
Is there anything else that would be different between a GTS-T and a TYPE M in a series 2 R33?
Thanks for any info.
BillyE.
Apparently all turbo R33 coupes are called Type-Ms. IMHO
I think he meant that they dropped the regular GTS-t (non-Type M) from '91 onwards Richard. Before '91 the GTS-t and Type M were sold in unison, after '91 they only sold Type Ms.
xRHETTx: You're right mate, ALL R33 turbo's are Type Ms.
... isn't it great that no ones mentioned 'M Spec'? Such a small thing but extremely irritating lol
You're saying my Nismo R32 Gtst M spec Nur Spec V-spec II Z-tune 40th anniversary edition isn't real?
I swear its real, some guy on the internet told me! :D
I swear its real, some guy on the internet told me! :huh:
dont they have the stroked RB39 and 12 turbos ?, i also heard you can drive them underwater !
no that's the 100th anniversary edition... the 40th only flies up to an altitude of 1000kms above sea level.
sorry i haddent checked this thread for a while and was interested to see the topic.
not trying to be argumentative but i wasnt refering to the 32 in my avitar. im quite aware thats a standard bar and i didnt refer to it either.
i thought that that "aero bumper" was a type M because i have only ever seen it on GTS4s or 32s with the whole kit. but i gess that doesnt realy make sence. i just thought it was rare so it had to be type M.
also the type M has the bigger brakes as all the brake guides say. try buying new rotors they ask you for the size as there is like 4 to chose from. type M being the bigest before GTR then you get V spec and so on. basicly ive rearly seen any of the type m rotors so if your saying most of the r32s imported to aus are type M where are the Big Brakes?
but i could be wrong as i have been befor and im sure i will be again soon.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
