  • Replies 54
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
To add to that this is a sad news for Military Aviation... Sure the FA18 is a great aircraft but will nothing will ever come close to the abilities of the F14-A Tomcat...
I stand at attention and solute with a Moment of Silence in Memory of the Tomcat!!!
:sad:
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1982651
Yes - I read this last week and felt a well of emotion similar to when you hear the 'Goose is dead' music ;)
But - considering the F14A was deisgned in the late '60s, it's probably time the old girl retired - much like Viper. And screw FA18s - I think they should just get a fleet of Mig-28s - afterall, they can do a 4G negative pushover despite having inverted flight tanks.
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1982731
From prep to year 10 I wanted to be a fighter pilot becuse of two things:
1.) Robotech their cartoon's in the form of planes were a derivitive of tomcats...
2.) Topgun/tomcats...
tomcats were/are my all time favourite plane... back in the day I actually wanted to migrate to the US just so I could have a chance of flying one... quite stupid really.. but sad none the less... ;):(:(
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1983291
tomcats were/are my all time favourite plane... back in the day I actually wanted to migrate to the US just so I could have a chance of flying one... quite stupid really.. but sad none the less... :):(:(
hahaha, robotech kicks ass! I wanted to be a pilot, but I wear contacts... so I did robotics at uni instead, I'll build a veritech yet :whoops:
this should be the next next gen :iluvff:
btw, I have all 3 seasons on dvd if anyone wants a copy at some stage
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1984072
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
