  • Replies 54
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
To add to that this is a sad news for Military Aviation... Sure the FA18 is a great aircraft but will nothing will ever come close to the abilities of the F14-A Tomcat...
I stand at attention and solute with a Moment of Silence in Memory of the Tomcat!!!
:sad:
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1982651
Yes - I read this last week and felt a well of emotion similar to when you hear the 'Goose is dead' music ;)
But - considering the F14A was deisgned in the late '60s, it's probably time the old girl retired - much like Viper. And screw FA18s - I think they should just get a fleet of Mig-28s - afterall, they can do a 4G negative pushover despite having inverted flight tanks.
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1982731
From prep to year 10 I wanted to be a fighter pilot becuse of two things:
1.) Robotech their cartoon's in the form of planes were a derivitive of tomcats...
2.) Topgun/tomcats...
tomcats were/are my all time favourite plane... back in the day I actually wanted to migrate to the US just so I could have a chance of flying one... quite stupid really.. but sad none the less... ;):(:(
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1983291
tomcats were/are my all time favourite plane... back in the day I actually wanted to migrate to the US just so I could have a chance of flying one... quite stupid really.. but sad none the less... :):(:(
hahaha, robotech kicks ass! I wanted to be a pilot, but I wear contacts... so I did robotics at uni instead, I'll build a veritech yet :whoops:
this should be the next next gen :iluvff:
btw, I have all 3 seasons on dvd if anyone wants a copy at some stage
https://www.sau.com.au/forums/topic/107506-no-more-top-gun/#findComment-1984072
