Have an R32 GTR with around 330kw atw and want to make it more like my evo which by comparison is heaps easier and safer to drive. At the moment the skyline isn't very predictable what with the 4wd cutting in very sudden and late. I've heard of ppl modding the sensors to create a permanent 60/40 split. Anyone got any info on how to do this? and will it be safe for the clutch/gearbox?
https://www.sau.com.au/forums/topic/107644-making-r32-gtr-full-time-awd/
it would kill your transfer case after a while i think. If you get an aftermarket torque splitter, you can dial in 40/60 if you wanted it that way. I only ever put in 20/80 but that was just to see how it worked. Doesn't Duncan's attessa controller work like that? I didnt read through the whole thing, too many pages! hah
Does anyone else have problems with the rear end trying to step out when on wide open throttle in a straight line, dry road?
I'm pushing 330awkw and for the first few km's my torque gauge will show up to about 10-20% to the front but after everything has warmed up (bout 5km) it never ever moves from rwd. That's with tein suspension and very very worn 255 tyres.
The only time apart from the first few km that my torque gauge moves is going up the gutter of my driveway and in the wet when i'm hammering it.
have u got a hicas lock bar? this make em alot more predictable. I think I saw some atessa controllers for sale in the group buy section.
most ATTESA controllers will allow you to set the maximum torque split, not the minimum torque split, which is what you want to do, effectively forcing a 50/50 torque split 100% of the time.
The ATTESA controller works off simple signals, so find the one that indicates traction loss at the rear wheels, then feed the ATTESA controller that signal constantly, and you'll have permanent AWD.
I can't imagine it being too healthy on the car's drivetrain though, as an Evo is designed to be a permanent AWD, wheras the GTR is a switchable RWD to AWD system. System developed using millions of dollars, vs $100 ATTESA controller :pinch:
330kw atw and it steps out in a straight line? Are you talking about launching hard in 1st gear? or what gear?
Mines not as bad as you make it out to be. Does your Evo have 330kw atw? :cheers: Maybe thats your problem :D
I agree with funky.
jimbob
i would put money down that your 4wd system is not operating correctly!
i had the same problem(r32gtr) with traction in 1st and sometimes 2nd gear accelerating in a straightline it would step out or just bounce of the limiter, that was with approx 350 kw's @ 4 wheels.
i have more power now and no traction issues in a straight line.
it can be a number of things wrong , pm me if you would like some ideas.
cheers russ
btw man after my own heart, i have an evo9 too, mine is silver.
Edited by giant
  • 1 month later...
I understand that the Skyline transfer case is not intended to send torque to the front for more than 12 to 18 seconds at a time. This is not a rally car like the WRX, but a track car. (If you break traction for more than 15 seconds you've got other issues!)
The multiplate wet clutch controlled by the ATTESA computer generates heat and will damage itself if it's working all the time.
Cheers,
Dan
This isnt the best idea but works well, put higher profile tyres on the front and it will be constantly showing about 10-15 on the torque split.
I noticed this after drifting in rear wheel drive mode making the tyres bald then putting awd back on, it stays constant awd...lol...
Do that in reverse and the awd will almost never come on with higher profile tyres on the back until big wheel spin..
Of the different electronic torque split controllers out there, the one i decided to go with was the Field torque controller. It simply allows you to adjust the speed that the ATTESSA system works, it doesnt simply over ride or replace it. You can adjust the electrical signal to the ecu to enable it to react more to your likeing, and can be set up to make the 4wd come in much sooner, rather than it running 4wd all the time.
What exactly does the HKS ETC and EDA do then?
The ETC allows you to dial in different front torque splits. It will be CONSTANT until you change it. For instance you can run 20/80 all day long if you want. It goes from 0 to 50 but 50 is not recommended.
EDA is an add on that allows you to choose what torque split you want til you hit a desired speed and it goes straight to RWD mode (hence the 'drag' part of the name)
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
