***fave Chillhood Comp/arcade Game***
  • Replies 88
Posted Images
nba jam playin with big heads :)
after burner was mad fun in that moving aircraft thing.
alex kid in miracle world was sick, you just close the cover of the master system and it plays hahaha, didnt need a cartridge.
captain comic on pc ownnnnned. i loved that on the 286s. instead of fire balls it used to shoot out asterix's ;) aahhh the memories.
all the street fighters were awesome.......
damn they should have like a timezone from the early 90s where you can go and play all the vintage games, that would be so much fun
hey guys, if you want all these games, you can download them from kazaa, or from some web page.
Get the emulators, then the games....
The Arcade emulator (the one that emulates the neo - geo arcade machine and others) is called mame. Also try winmame, winkawaks...
The atari emulator is called stella
the nintendo emulator is called nesticle, and there is also one for super nintendo, but i forgot what its called....
Also try looking for sega, dreamcast, saturn emulators, whatever you want, you'll find it!!!!!
I have all of these games, plus more (about 1000 I think in total). EVERY SINGLE game from the 70's 80's, 90's, and many recent ones, i have em all, and they cost me absolutely nothing!!!
I have to admit though, games you loved back then seem really boring now.....
Zahos
I spent so much of my childhood playing bloody Commodore 64 & NES.....
Then I graduated to Timezone. SF2 changed everyone's life back then.....
Now I still play PS2 & GameCube far too much.....
I wonder what we'll be doing when we're all 50......
  • 8 years later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
