Build ski boats for a living and applied my knowledge of restoring persrex windscreens. Basically a heavy cutting polish and a buff with a lambswool buff pad followed by a couple coats of wax to preserve the finish. The end result was simply stunning, the only difference when compared to a new headlight was a faint light brown tinge that was bearly noticable. Good luck.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
