Hey,
I have found an r32 gtr that is in good condition and i am very happy with. but one problem, the oil pressure gauge didn't move when we drove it. Just wondering if this is a fault with the gauge or if it actually has no oil pressure. has anyone had any experiences with these cars having a faulty oil pressure gauge? it has white nismo aftermarket gauge fitted.
cheers guys
https://www.sau.com.au/forums/topic/108673-r32-gtr-oil-pressure/
If the engine didn't have oil pressure, I'm sure it would be "dead" in next to no time.
Check the oil level on the dipstick. If it's OK, then it's likely the engine will have oil pressure.
It is (hopefully) a dead sender. Ordinarily, you should have quite high oil pressure when starting from cold.
Hey,
cheers guys
Dean,
Chances are it is a dodgy sender unit or gauge. Having said that you need to find out for sure. Get it checked by a mechanic with a proper gauge before you buy it. Remember a dead RB26 will cost a bundle of money to put right....
couldnt have put it better. yes it's probably for the gauge but you'd be a fool to buy it assuming the best case. take it to a mechanic and have them connect a mechanical pressure gauge so you can find out for sure.
ok turns out it was the sender unit, after putting on a manual gauge everything turned out ok. but while it was in the shop we had the change to take a good look under the car, and there appears to be a bit of oil underneath. too hard to tell exactly where its coming from, its around the area of the turbos. i know it must be hard to tell, but how bad does this sound? should i forget about this car?
It is not uncommon for there to be leaks on the seals of the oil lines that feed/return oil from the turbos. Not the end of the world by any means, but a bit of a pain to find and then fix.
im just trying to be sure before i buy it. i dont want to get it and find out theres a major problem thats gonna cost thousands to fix. i was ready to put my deposit on today but now im not sure. it drove really well, and looks all good condition. everything is original except for different brakes.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
