12" Sub In R32
krayzie32
 Share
Hi Guys
Im Doin My Sound System Install.
The Centre Pieces of my Audio Install are
Fusion Powerplant 12" DVC Sub
Fusion Jonah Lomu 1211D 1250RMS@2Ohm Monoblock Amp
The problem im having is want really deep bass... and i dont want to spend $500odd dollars on a custom built box.
Can someone please give me suggestions, pictures, diagrams, designs etc that will make the 12" Sub the centre piece. i have tried purchasing boxes but most of them do not fit in the boot. Ported or non Ported
Im am going to have a crack at making one myself but as my skyline wont be with me for the next 2weeks i wont be able to measure up the boot or design anything visually.
If there is anyone experienced in the matter or own a skyline and have succesfully installed a 12" sub in their R32 please post Dimensions of box or help me design a box that i can cut up and put together
This Page will not only benefit me but also alot of other sau'ers
Thank you very much
Krayzie
You should be able to find some pre-fab boxes that will fit. Both my friends have the powerplant 12" in a ported pre-fab box and there is absolutely nothing wrong with the sound. Both had space restrictions meaning they had to find an odd shaped box. Autobarn had one which is thin and a little taller which means you can install it upright if you only have a thin space, or lay it on its back if you don't have much height to play with. It sorta looks like this with the back a little sloped aswell:
__
|__/
But seriously, just design a box of your own with the dimensions that will best fit your application, its not that hard. A box like above is more difficult to make if you don't have the right tools because of the angle joins thats why my friends both went ported pre-fab'd boxes.
By the way, I'm very impressed with the powerplant subs, they play very hard when given the 400-500WRMS and handle the low lows with ease. That amp you have chosen may not be the best choice (unless u want to expand later on with more subs). The DVC is 2+2 ohm meaning you can either run it at 1ohm or 4ohms, which will be what is shown to the amp. I Doubt that amp will be able to run at 1-ohm (if it can then great but it will be massively overpowering the sub), or you can run it at 4ohms and it will probably give you 600WRMS and be ok for the sub (but still take it easy). Essentially what I'm trying to say is that you should be able to find a cheaper amp for your current needs, unless you want to get more subs in the future.
Fixxxer
__
|__/
Fixxxer
Thanks for the tip dude
But if i remember correctly The Powerplant DVC is 4Ohm/Coil
the 1ohm & 4 ohm Load impedence is only if im running multiple subs but im planning to run 1x 12" Powerplant atm on 2ohm With Parallel Voice Coil Wiring
http://fusioncaraudio.com/products.php?act...w&product_id=30
Click Tech info:
Outside Dia. 319mm
Impedance 4 Ohm Per Coil
the amp i chose will put out 1250WRMS @ 2ohm
14.4 Volt Power Output Specification
800 WRMS x 1 into 4 Ohms
1250 WRMS x 1 into 2 Ohms
And Im Planning To Go 2x10" Fusion Jonah Lomus in the near future
im pretty sure this amp should be able to power that as well.
Plus If i told i got this amp for free would you believe it
The amp for free..... yes I don't believe it, haha :laugh:
Ohhh yep, my mistake, it is 4ohm per coil.
Just go easy with the gains on that amp.
You won't be disappointed with the powerplant.
Just remember though, I think the Johna Lomu subs are also DVC (4ohms per coil). With 2 subs you won't be able to make that magical 2ohm rating for your amp. But if its for free then who cares.
I'd think about grabbing another 12" powerplant in the future if you want low low bass, a lot cheaper too :laugh:
Happy bumping.....
Fixxxer
the space in a r32 boot is very tight. there are pics of my install on here somewhere and i mounted the sub in a beva box on the left side of the boot facing in and over the 2 amps... i would have liked it up towards the back seats but barely enough room to get in there, even when i did the entire custom wood floor in my boot i battled with space.
Ed
Thanks for the advice ED
Mr 32 is doin my install by wednesday so ill post some pics of how it looks by then
must i say Mr 32 i am very envious of your 32GTR but hopefully in the near future i will have one too.
Just on the subject of subwoofers and enclosures remember that you must design the enclosure correctly. This of course means you have to first check out all the Thiele / Small specs of the subwoofer itself. This alone usually rules out most pre-fab ones. You then must take the T/S specs along with the resonant frequency of the car, the volume of the car, the volume level the customer desires and the music they listen too and then you must simulate between forty and sixty enclosures on the PC until you get the correct response curve to match what sound you desire. Then you need to build it correctly but I don't think I need to go further into that.
On the subject of what type of enclosure, you might want to have a quick read of this.:P
Edited by Fhrx
Thanks for the info FHRX and I understand all those tiny details that go into an award winning system.
I'm in no way an audiophile and I definately haven't heard the best bass there is to hear, but I absolutely enjoy listening to that 12" powerplant in that prefab box. To me its all I need.
Fixxxer
 Share
    • New alignment and matching tires is great and f*ck me are the German roads fast. Took another trip to the Nurburgring yesterday with my buddy and the car feels great in the dry - a lot of mechanical grip. In corners at 140-160kph I felt like I could keep going.
    • Has anyone else been swarmed by morons with cell phones taking pictures of their car? A few of you may know, I recently moved from Japan to Europe and brought my R34 with me. Since arriving I've driven the car a handful of times and without fail have had people filming/taking photos of me with the car to a point where it's becoming annoying and a bit hazardous. Yesterday, whilst driving with my buddy (R32 GTR) on the highway, I spotted three cars pulling alongside with some twat hanging out the window recording with his phone. This one VW Golf came alongside in the passing lane and held position preventing me from being able to pull out and pass slower traffic in my lane so I gestured to him to F*ck off.  It seems when people have approached me, in the car park, at work (drove there once - mistake), gas station etc. they ask the same questions: "why doesn't it have a wing?" and "how much power does it have?"; the latter has been met with pure disappointment when I told the kid it's stock. Of course, Japan was a totally different story, the people are a lot more subtle and have never bothered me about my car or have been polite in doing so. Has it always been like this in Western countries, and what are your experiences? I just don't recall this ever, or maybe I didn't have a nice enough car back when I was growing up in the UK. I've taken the R34 out a total of six times since it landed and besides going to the Nurburgring area it's becoming more of a pain than anything.
    • I had a similar situation with my R32 GTS4. I replaced that solenoid, but it hasn't solved the problem. So its possible the pump is failing. It seems you need to drop the diff in order to do anything that might fix this. So its important to know exactly what the problem is. Or just replace / repair everything while the diff is out.
    • Yep, I was supprised. Its all about flow rather then housing size.  Doing G35-900 Vs ATR45SS-1 Next. 62mm V 61mm.
    • Of course sometimes you cannot go with the cheaper alternative but I try to weigh it up for the application - am I competing or am I going to the track ten times p/yr. As long as there’s enough information out there to back the cheaper alternative as a good option I’ll go for that.   I’m a bit of a bastard though as it’s my job to reduce costs, particularly on non income generating assets. EUR 500 saved for the diff + EUR 1,000 saved on BC racing over Bilstein and then say EUR 300 versus EUR 600 on an off brand windscreen versus OEM (for example) soon accumulates. I mean, I’m probably gonna put the car in the ditch anyway. Absolutely do not take this as a justification for always buying cheap shitty parts, just a rationale for doing your research and considering what’s necessary for your application.
