awwwwwwwww how sweet......
you share a birthday with Marko (aka SKY^RKT)
Happy Birthday guys
just think, uve got 15 yrs to go until they go inside ur willy!
I have no idea what that was about... but it sounds a bit frightening!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
