Hks 2835 turbo...
Pics please [email protected]
1. Flange type?
2. Negotiable?
3. Is it real or a copy?
4. Condition (km's, shaft play)
Whats needed other than dump pipe and oil/water lines to make it work for me???
Doughboy, Roy tells me you have GTR intercooler alloy piping kits.
Can you let me know price and what the kit includes.
Cheers mate.
try emailing doughboy then, he is prob busy with work or other stuff.
doughboy - morgs and I will be in contact on sunday :thumbsup:
Impul - the Rays nuts are black
Stan - I've got both, will PM you
Black32 - I'll have a look, will have to open a few diffs to check.
driftking - yes they fit on an S2 GTS-t
I wish to purchase these parts.
I'm still waiting for you to PM me
Thanks
Stan
Oh sorry, have been a bit busy and not checked up on this thread.
Stan - pm sent
2835R - have got 3 good ones here, minimal shaft play, good condition. All have either the T25 flange internal gate (0.86 A/R) or 1.12 ext gate housing
Geoff - Alloy pipe kit was sold with a turbo setup
Black32 - checked the diffs out, all I have left are 3.54 ratios and a 3.69. Have 4.36 and a 4.11 but they stay with the aftermarket mechanical diffs that they are bolted to.
Will update the first page, have sold a bunch of stuff already.
Hey doughboy,
about the hks 2835r im looking for one of these, but wondering how many kms they got and how much shaft play does it have, and also would you recommend a rebuild, btw how much are rebuilds on these turbos and who through,
Cheers Adam
  • 3 weeks later...
ha man, ive PM'ed you and no reply on contact details. if you can fwd me your details i'll be able to look at the r34 diff you have for sale. Do you have any r32 gts4 front and rear diff ctrs as well??????
thanks
  • 2 months later...
  • 3 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
