I think he meant modified the cylinder head for increased oil return to the sump. We drill the oil return galleries and smooth the oil flow passages with the die grinder. Plus we fit an external oil return from the rear of cylinder head direct to the sump. Add this to the oil restriction (one feed restricted and one blocked off) in the top of the block and you have a good chance of the oil staying in the sump, not being trapped in the cylinder head. Or filling up your catch can.
TIP; If ordering the sump from Performance Metalcraft make sure you specify a fitting for an oil temperature sensor. Plus a fitting for the external oil return hose into the top of the LHS wing.
:P Cheers :D
Gary,
Your wealth of knowledge never ceases to amaze :P
:yes: Cheers ;)
Hi Gary - can you post a pic (or sketch) of how you add the external oil return line?
Cheers
Gav
Good looking pan, but why not dry sump ?
I had a JUN baffle & a Trust sump extension, overkill prehaps but I did a serious launch with a 35k engine & ended up with a blown #6 big end, I spent a fortune rebuilding it , only for the same thing to happen again after the first few hard launches. I am now dry sumping, if you add up the cost of all the wet parts (ie jun pump 15 hundy, baffle 5 hundy, trust extension 5 hundy, welding 2 hundy, ) & compare this with dry sumping it's a joke (ie as new s/h 4 stage weaver pump from ebay 7 hundy new moroso drag tank from summit 7 hundy, plus the cost of all the lines, fittings, and a couple of filters about another 7 hundy, plus modifying the sump pan 7 hundy, & finally a weaver drive kit for 2 hundy) I really wonder why I did not dry sump in the first place ! I would appreciate your comments ?
firstly can i just ask how a dry sump works? also as the above states about the trust ext and jun baffle why did it blow the big end was it from lack of oil? also did it have an extended oil pick up, of been told this should help? im just new to this and need to know as the last thing i want is to blow this motor again......
thanks guys im glad this topic has taken off.
JagR33 runs a stock sump i believe with his tracked 33 GTR, 350awkw :P
There are numerous others too.
Its all about the prep work to head and other things, then you wont need a sump for your aims Lee :D
That's correct, standard sump, Ben (Racepace) assured me it would be OK, as long as oil is at the right level....
Done 3 trackdays, so far so good....
best idea it to google: "what is a dry sump" or "dry sump system" or similar then you can learn how it works.
I have done a dry sump on my rb30/26 in my gtr. Car not running yet but let me tell you (not to scare anyone off) doing a dry sump setup on a foreign motor (ie all the parts are for chevs not nissan) is farkin tuff, not easy at all. If you have the mechanical know how it will make it easier but still alot of headaches, like pulley sizing to ensure enough oil and pressure on idle etc....
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
