forgot to mention I have 1994 R33 GTS4,
One thing I noticed is once the 4WD and ABS led flashes the SLIP led doesnt work anymore, normally it flashes when the rear wheels loos control or slips. which means it has switched back to RWD from 4WD.mmmmmmm, No I dont know why ABS led allways cometogether with 4WD??????
Maybe a electrical problem.................. :):):mad:
Sounds like you rear ABS sensor/s are faulty or damaged.
Both ABS and ATTESSA systems use the ABS sensors to determine slip/skiding/etc.
I took my car to a workshop, which they hook it up to a handheld computer thingy, it came up saying "G sensor error"
By the way where is the ABS sensor can be found on ? im sure all 4 wheels got them but no idea what it looks like or where it is exactly located in?
any help...................a pictur maybe...
Cheers
The G sensor is a small metal box in the centre console rear of the gearshift. You will see it as soon as you take the console off.
It has a small window on the front which apparently goes red when the sensor is busted - don't forget your problem could be the wiring between the sensor and the computer as well
The ABS sensors are little toothed wheels - front ones are on the hubs and rear ones are next to the diff. There is a small sensor attached to the diff or hub that reads how many teeth go by to calculate wheel speed.
Cheers, Thanks mate. bythe way i found more infor regarding this issue on another web site as well.
http://www.gtr.co.uk/forum/upload/46982-ca...my-gtr33-2.html
FYI----(The following has been copied from above mentioned site)
If you disconnected the battery you may of just deleted all the fault codes from the ECU,s that have recorded the faults.
Over the last few years we have come to notice what causes these faults and mostly are as follows in order which we have noticed.
A 33 has Electric Hicas so the Power steering fluid fix will not work ( the 32 is the only car that has hyraulic Hicas )
Normally if the 4wd lights comes on by itself it will be a low fluid level.
If the 4wd lights and ABS lights come on it will be throttle switch or ABS sensor.
If the 4wd/ABS/HICAS lights come on normally the rear wiper pipe broken and it has flooded the ECU,s in the boot.
Cheers
Chinthana
  • 3 weeks later...
what exactly is the throttle switch?
having just messed around with the throttle getting wiring through the fire wall my 4wd + ABS lights have come on. Guessing its related.
Cheers
Chinthana
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
