Thanks guys for the help.... Can't wait to get this done to mine....Because my motor is out for Top end build and re-assembly and i might as well do that and the restrictor while its out.....This is a good as thread. lol. Thank god for the Aussie's.
  • 3 weeks later...
So would there be any issue welding the plug below the oil level for the external oil return?
I bought the rear drain kit from Dane at Densynz and he instructed to weld the plug below oil level because high crankcase pressure would cause the oil to stall inside the line..
There are two takes and i'm confused which one is the more functional route..
So who's blocked off the rear oil feed of their RB20 or R32 RB25DE non-vct head? (i.e only one restrictor feeding the head)
I've tried to see if the two feeds within the head are joined and be buggered if I can feel any vac through the rear feed. :S
Maybe its the way I'm testing it. I've blocked off everything there is to block and there is a good deal of vac on the one oil feed yet the other see's nothing. :D
I believe you can probably run it above the oil level so long as its on the exhaust side i think(could be inlet, have to check with someone who knows exactly) so the crank vacuum helps pull the oil out of the return. I would think exhaust side, as the factory scraper breaks the vacuum from the inlet side so it also being the low point of the sump would be coping all the oil and broken windage. Need gary to cross check my thinkings, he would know for shizzle.
  • 4 weeks later...
I've been putting it off for a very long time.
Finally bit the bullet put faith in SK, closed my eyes blocked off the rear, 1.5mm up front and there appears to still be plenty of oil flicking around in the cam covers. I'll put a few hundred kays on it and check it out but I'm certian it will be all good.
R32 RB25DE head.
I think an Apology is in order for Gary (Sydneykid).
I doubted his suggestion that a 1.5mm restrictor up front and rear blocked off was perfecty fine for the R32 RB25DE head with no VCT.
So I went and did it anyway :thumbsup: and it is 100% percent fine.
Plenty of oil up top; top ends nice and quiet; no tapping when it comes off a rev; its all good.
So my apologies Buddy!
I've checked catch cans and there's absolutely no blowby; completely dry.
Yours doesn't count as you have an additional feed via the VCT to the head. :P
My problem was I didn't know of any one with an Rb20DET or R32 Rb25DE non vct head that had run with 1 restrictor blocked and a 1.5mm up front. The R32 Rb25DE and Rb20 heads are near identical apart from slightly larger ports and the larger combustion chamber/valves etc. So I wasn't completely comfortable using the R33+ Rb25 VCT head as a comparison that it really did work without problems. :yes:
But yes.. Still more than enough oil floating around; I've noticed I can now see the top of the bucket where as prior oil was constantly filled 1/4 up the base of the cam so impossible to see the top of the bucket.
Hello guys, i think it was already mentioned but do you have any sources for the block off and 1.0mm oil restrictor for my RB25DET ? Where can i buy them ? Tomei is only selling the 1.5mm oil restriktor and no block off plug. Thanks in advance.
one thing i dont get is.. all the machining etc etc. lining up the gasket etc.. just how much oil do you think will have to "build up" to flow down the standard oil drains. all 18 of them. i rekon mayby 2-300ml at most..
i mean its all a good idea but is it really that efective? has anyone done any tests to back this up? like on a circuit car with the standard sump with and without the drain?
or is blowby the issue here, where it all blows up the oil returns slowing the return of oil back to the sump?
Dave, watching the amount of fumes/smoke exiting the catch can vent at high rpm on the dyno I'd suggest there is some resistance to the head return flow but not massive. Still not entirely convinced a return is necessary but if you are considering fitting one then at build is the only time that is sensible.
hans, it doesn't really matter but most go left as that is the natural lean of the engine and run it into the sump.
we tapped the left of the head and run it aroudn the back to the right of the sump in front of the diff - just enough room to fit it, although the fitting in the head will foul the standard boost lines that run around the bacl
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
