NP mate. it does not require welding but it will require your machineist to machine down the crank and fit it correctly. its not a easy job and you have to have the crank out of the engine to do the task.
what was the other question? did you read through this thread ? it has everything you need.
always balance everything that goes up and down and round and round. Might as clean up the crank too while there, any dags and casting marks clean it up and get it slippery smooth.
In regards to the RB25 , why is the front feed blocked off and the rear feed restricted but with the other engines its the rear feed that gets blocked off and the front feed get's the restrictor as per sydneykids table ??
we dont know where sydney kid comes up with his ideas but they have been proven to work time after time after time so its a good idea not to ask questions how he comes up with it...
I think it may be because the rb25 has hydro lifters and its required to have it setup that way to run them properly where the gtr has solids which does not need the same kind of oil configuration.
Mine is done as per Sydney kids instructions and its been running for 2 years and 363rwkw.
There are many others whos are running well too. I dont know why people have to question it all the time.
well i certainly do not know thats why i am asking these question's b4 i put the motor together .. i want to be 100% sure all is correct ..
in saying that guilt-toy if you install the non vct 25 head you block of the rear and feed the front but with the 25 vct head its opposite and both have hydraulic lifters..
thats is correct??
I run the non-vct RB25 head.
I blocked off the rear restrictor as the Rb26's are and run a 1.5mm restrictor up font.
Works fine no ticks, pops etc. Went from shit loads of oil everywhere over 5500rpm+ to a bone dry catch can. Still plenty of oil floating around in the cam covers. Prior on idle oil was puddled up to the base of the cam so you couldn't see the lifter. Now u can.
As a few have experienced; if you experience hydraulic lifter tick once the motor is warm its a tell tale sign the motors on its last legs. Recently happened to a mate of mine running an rb30det.
what went on your mates engine when it went ? i get lifter tick for about 5 seconds when i start the engine on cold startup only...
just wondering what went on your mates engine
Lifter tick when the oil was warm and poor oil pressure no bottom end knocks or noises. The lifters were silent when cold.
Mine is fairly decent on cold start up, I only get an occasional tick. I can't remember the last time it ticked but I haven't been driving the car during the week for a while.
The RB20 was the same. Occasional tick.
Yeah well i checked my oil change sticker and it has been 6000km's since a oil change!! so thats why they would be ticking.. oil is getting a little old but its 300v chrono which is known to last longer then normal fully synthetic oil.
will change it in the next week or 2 :) ooooopppss
thats a pretty over the top solution Beyond Horizon, you will never fit the standard piping back on if you go a fitting like that. A simple 90o angle with 1/2 hose barbs on one side and 3/8 BSP thread on the other can be tapped into the head just to the right of the fitting in that pic - much easier, smaller and about $3 for the fitting
But will it flow as well, bearing in mind we are talking gravity feed here?
Do you know where i can find some pictures of this modification you're talking about or do you have some ?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
