Dazmo, what kind of dollar is it for your dry sump and is there anyway of fitting one into a rb with Aircond and power steering intact :thumbsup:?
Hey mate i could not give you an exact figure on what my dry sump has cost me as i have not added up all the braided line and fittings but hi octane do a dry sump kit that retains the ac if you want to I think they sell them for around 6 or 7k without the lines,fittings,tanks or breather tank etc. A quick break down of my set up without lines or fittings. modified sump (purchased from hi octane) $2300,5 stage peterson pump $1850,gear drive for pump and balancer $190,custom drive for balancer $150,Peterson 3 gallon oil tank $650,breather tank $120,peterson scavage filters 4 of @ $70,custom pump mount $350,oil sandwich plate $150 and a shitload of braided hose and fittings couldn't tell how much dollars worth. i would say at least $3-4k worth so is not cheap but is a lot cheaper than a f----d engine especially as my car is going to live its whole life on the track.
  • Like 1
this is the oil pump which im using
its CNC machined from P20 tool steel
upgrade oil pumps such as JUN are laser cut which weakens the metal because its heating it up while its cutting where as this one is machined from cold steel
it does take alot longer to machine up compared to laser cutting
Any idea if the aftermarket pumps are heat treated and/or annealed at all? Generally if tool steel is used, its sent for heat treatment to correct the grain structure in the steel, making it tougher and/or harder.. therefore the way the steel is cut is irrelevant
Edited by Love_Hate
http://www.driftworks.com/forum/technical/...rb-engines.html
i have found recently that on all the rb26 we have rebuilt the the bottom of the conrod and the conrod cap the two mating faces were the big end bolts go are not flat!!! and thats why they keep doing bottom ends as there is room for the bearing to move and destroy its self .
once we flattend these off so they were perfectly flat on both the rod and the cap the engines have been great skid all day on the limiter
i would check this on some of your old engines
kind regards jamie
What do you guys think about that ? Could that also be an issue, and not the balancer and oil pump drive letting go ?
I'm drilling mine out to 10mm, to match the head gasket.
Diameter of one of the oil drain holes, where it steps to the larger diameter is 9.65mm, and gasket was 10mm.
Oh yea, thanks. No issues with it not lining up with the gasket?
Moar on oil..
can i remove the stock oil cooler? bolted to the side of the block?
This is something I am interested in doing, too. As far as I can see the issue would be you lose the spring loaded oil bypass system, should the oil filter clog or collapse internally. I am thinking of tapping the block to take a filter thread adapter straight on to its side, and binning the cooler and associated bits altogether. I would then accept that should a filter block that safeguard was absent, and I would also take care to not rev the engine hard from cold, in case the bypass was used to pass viscous oil around the filter in such circumstances (which I think is doubtful). Please critique this.
My mate came over tonite and looked at my new motor and said, fu*k that thing off, thats some weight you can loose..
i'm sure another bypass system can be made or can be worked out to work properly..
Thanks for the details Dazmo :laugh:
I am still adding up the numbers....that's a lot of money!
:) Probably a good call. Piss the rb26 off and drop an rb30 under there. No issues with the std water oil cooler then as the rb30's have the relief inside the block. :D
Thanks for the details Dazmo :)
you'd probably end up close to the 6-7k mark if you got most of the stuff done yourself
the braided lines are really the big killer, you will spend close to 2k alone on just lines and fittings. and may even go over that price
the sump tank pump and brackets shouldn't cost that much at all in the end maybe 4k but i guess it depends if you know someone good with a welder and some dry sumping experience
haha but i just spend lots on a n1 block.. there is no rb30 ever going on here!!
Edited by Angus Smart
For the price of the N1 block you could have built a forged rb30 bottom end.
yerp and then new turbos, new exhaust, and a whole heap of other new things i would have needed to suit the rb30. i did the math and this is the way i wanted to go... and besides i now have two motors at home so i can sell off some old bits to recoup costs.
and the price of my n1 block was quiet cheap..
yep they are also heat treated
theres no point using tool steel if ur not going to heat treat it
  • 3 weeks later...
so what do you think about my oil setup....
Tomei oil pump, Trust sump extension, Tomei oil baffle, Canton 2qt Accusump (fitted into Trust remote oil cooler), Tomei 1.5mm oil restrictor...and that's it. No head drain. It's all coming together this week. I figured a 1 liter overfill, plus the 1.5 extra liters with the Trust sump extension should help out in case I get a head overfilled with oil. Mines cam cover baffles should keep the oil in, and I've got a Nismo oil separator as well to help return oil thrown out of the cam covers. I've basically done everything possible except the head drain (short of going dry sump of course). Should I have done the head drain? Are there any track GT-Rs in Australia that run without a head drain?
as this is for oil control in rb;s, though i might aswell post in here,
i just put a new rb into my car, the oil pressure is reading 4 on my defi gauge, i thought its ment to be 2 on idle, oil is a tiny bit higher than the high mark, probably closer to the hump, is that why its at 4 the oil pressure or could this engine have after maket stuff in it like pump or something, etc....
nice thread btw JV
Hey guys, is it possible to install a Sump Baffle Kit without pulling out the engine? I've rang about 5 workshops, and out of those 5 only one was willing to do it without pulling out the engine, so I wonder whether it can be done at all or if it can be done but it will be a shit job.
You have to pull gearbox to get to the rear small bolts,
Support engine when you drop the front crossmember to remove the sump.
It's a lot easier to pull engine out and do it out of the car. It is possible though, just a real pain.
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
