  • 1 month later...
It would be good to get some hard evidence about the rear "drain". Some say, and I tend to agree, that it really functions as a sump breather in which case it might as well go to the catch can as to the back of the head. Someone talked about putting a plastic hose on the head drain and sticking a video camera in there but there is a much simpler way.
What is needed is someone who has overcome the problem of filling the cam covers with oil on the track (not someone still experiencing this problem because if the cam covers really are filling up with oil - as happens - then some of that oil is bound to go down a rear head drain pipe) to take the end that goes to the sump and stick it (securely) in a container and run a breather to atmosphere or a catch can from the fitting on the sump it came off. Then give it some stick for a few laps and see how much, if any, oil is in the container. It wold take a selfless searcher for truth to do this because this person would have already solved their problems and for them it would only be of academic interest but for the rest of the RB world it would be valuable information!!
I couldn't do 2 laps without filling my catch can. I had a reinmax pump and revving to 9200rpm on a 3ltr. Changed the restrictor to 1.1mm from 1.5 and installed a head drain. I then had not a single drop of oil out the catch can after 20 laps. Cams had plenty of lubrication. The rear head drain hose burnt closed and made no difference to how much oil was in the head. It just comes down to matching your oil pump flow to your restrictor size.
I also had mines triple flow baffles and a 1.1 litre increased baffled sump.
Matt
Thanks for that. So you're saying the rear drain doesn't drain. Was the head an RB26 or 25, solid or hydraulic lifters? Just one oil feed no vct? And the mines triple flow baffles are they in the cam covers (as opposed to sump baffles)?
Thanks
Bob
I bought 2 x Tomei 1.5mm oil restrictors for my RB25DET Neo build. Yes I know best practice is to block 1 completely and run the restrictor in the other. Anyway I just went to put them in and realised the standard Nissan restrictors are already 1.5mm each.
My understanding was that the standard restrictors are 2mm. Maybe they are 1.5mm on the Neo as they come standard with an N1 oil pump?
Anyway I think I will get 2 x 1.2mm restrictors and run with those.
rb30 are 2mm. all rb25s are 3 x 1.5mm factory, with the front being solely for vct
Interesting. I'm about to pull the head off of my NEO engine. Jonno, What would you suggest to do with the restrictors if i'm retaining the factory N1 oil pump the NEO comes with.
I tried to follow sydney kids table as best as i could and also worked out the cross sectional area of different size restrictors. But still pulling my hair out as to which one to choose.
Now going by Simon-S14's NEO which is a full on drift car which sits on the limiter like no tomorrow, he says he has no issue with oil pumping into the head. However he is at high revs for shorter periods of time than a circuit car.
I was thinking of blocking the centre oil feed as per SK's table and maybe going down to a 1 - 1.3mm oil restrictor in the rear.
Any thoughts?
I just pulled my engine out as it was filling the can covers with oil and putting out great clouds of smoke on the track and oiling up the whole engine bay. The block was bought already prepared so I was suprised to find it already had 2 x 1.2mm restrictors. We are fitting 2 x 1.0mm restrictors and two 20mm breathers to the sump. Will let you know how it pans out.
What engine and oil pump do you have?
the tomeis squash down to around 1.2-1.3mm once installed.
RB30/25 N1 pump. I know SK's chart says to completely block one feed but my mechanic thinks that's not safe. Engine is back in and should be running tomorrow. He has also had good results with putting RB26 cam covers with Mines baffles but there is no room on my engine because of the position of the w/g on my custom made manifold.
Yeah id like to put RB26 covers on mine with the baffle plates but factory plenum doesnt allow to.
Hydraulic lifters and VCT enabled
Ok then, well i have a NEO with factory N1 oil pump. If you were pumping too much oil into your head with 1.2mm restrictors then i'll probably block one feed and run something like a 1.3mm in the other.
I have solid lifters so i can block one completely, probably not the best to do it with yours as you still have hyd buckets.
When will it be on the track again so you can compare results by going with 1.0mm restrictors?
As well as the restrictors I am hoping that the two 20mm breathers in the sump will help with oil return from the head.
Also have Tomei baffle kit in the (awd) sump.
Hampton Downs 25 March but I should get some indications on the dyno as I am upping the boost from the initial 10psi to 18 - 21. When it is tuned I may be able to fit in a test day at Pukekohe late in Feb. Will keep you posted with any results.
Does this mean your running 2x 20mm breathers from the top of the intake side of the sump to the top of the catch can?
I am going to drill out the 5 x oil return galleries in the block (9.5mm) and will clean up the 2 larger oil returns at the back of the block (RB25DET Neo).
I don't currently have the head with me as it is currently being checked and machined etc, but I assume I am correct in thinking that the galleries in the head will need to drilled out to match.
As I don't have it with me so I cant quite remember where those galleries end up in the head, but I assume you need to drill them out with the cams not installed?
Trouble is it will comeback all clean and assembled, I would rather not go drilling into it >_<
Get your machinist to do the drilling for you.
But yes i'm doing the same. But i'll probably strip the head myself, do the drains, then get my machinist to just face the head for a new head gasket. Done.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
