  • Replies 164
I pulled 242rwhp with only a pod and 3' exhaust out of the turbo in an auto with the rb2.5t on psi s dyno in perth
then had a front mount and eboost and did 244rwhp at 8 psi and then 250 at 10psi on xspeeds dyno
both places said they had never seen an auto pull that much with thous mods only
james
Ignition system seems to play a part in the power differences perhaps.
I notice that many of the curves are similar on 240/50rwhp cars to the 300ish ones, with the difference coming in up top. If the spark isn't as clean this could account for the power difference. The coils and wires under the cover get very very hot and this effects resistance and reduces the efficiency of wires over time with heat cycling.
no way r33's can make that much power.
the above poster is claiming 267.2rwhp on stock boost stock turbo, HELLO THATS IMPOSSIBLE.
r34 gtts with running 12-14psi with powercf, hi flow exhaust etc etc are only making 260-270HP on the stock turbo.
Edited by noise
I am pretty sure that 25 neo's can only do 195-205rwkw max from stock turbo.
Thats 261.50-274.90rwhp.
how is an older less powerfull rb25 going to put out more power with fewer mods?
it isnt, stop talking shit.
or point me in the direction of threads of people posting dyno sheets to show otherwise.
i dont know why yours didnt make more then 270 rwhp
Shall I direct you to threads showing you this? how about you go to a workshop with a database of dyno sheets and look at them?
I didnt even own the car when it made the power, so i have no need whatsoever to talk it up. Those numbers where made on a DD accredited dyno
The car had
A garrett cooler, not gtr sized, just under.
A mettams morley dump and front, leading into a apexi cat back. 3 inch hi flow cat
11 psi
Walbro fuel pump
KN air filter
s2 motor
manual
standard timing
272 rwhp.
www.antilag.com/personal/tom/my31 for pics of the engine bay etc, so you can see it wasnt packing a hidden t88 etc.
tj
and back to the argument ... 319 rwhp is very very very hard to believe
Edited by dan_the_man
umm ok...
im not saying 319rwhp is possable...
but why have many not just one or two, rb25 run between 280-300rwhp on stock turbo?
just because ur r34 didnt make it, doesnt mean its not possable for another rb25 power cars to do it
james
Hey James! man hows that happening? I only got 202rwhp with 3" exhaust & POD! Damn I'm pisst! What PSI was it at b4 FMIC etc?
Back to the basics,Im sure there not stock but they sure look untouched.
NEO engines have nastie combustion chambers for polution reasons and will ping at less timing than an R33 RB25.
Some shops are not aware the NEO head is different,A few weeks ago a shop removed the head of a NEO fitted to an R33 finding it looked different told the guy the head was an NA head and had to be replaced.
So yes theres lots of misinformation around.
Some strange things have happend to new cars like in the early 70s Fords GTHO Phase 4 was shelved by the government (AS were GM etc)
so ford stuck some parts on a 2 door falcon and tagged it RPO87
the rest ended up in ZF Fairlanes without the new owners ever knowing
and over the years we saw stockers with Noddy iron 9in diffs winged sumps and 4V heads with 780cfm Carbs etc so who knows what may have happened with these cars,Prolly modded very early in life by very carefull mechanics?
got to remember that the dyno is a tuning aid at the end of the day. There is some value in relative comparisons but, not something people need to get hung up on if their car is doing what they want on the road or track. If your tuner is handing the car back to you with improved power characteristics this is what matters.
Some R33 gtst 200rwkw+ cars have run against my old R33 gtst (dyno of 170rwkw) and had an ass whipping both in 1/4 mile time and terminal speed.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
