  • 3 weeks later...
  • 3 weeks later...
white r32 gtr by TRP c16 and mickeys 10.02@143 . pump fuel 23 psi and 245 x18s 11.02@129 on the brakes so as not to get kicked out but they still showed me the back gate.Dont want to cage but might have to as im addicted.Tony rigoli performance 3 ltr stoker and t51r and stock gearbox.
13.499 @ 105.32MPH
1st time at drags ,
Factory ECU
Running 9 PSI with GT3071R
wow...id certainly be looking for an a/market ECU asap if running a turbo like that Glenn...
WSID 01/07/09
[email protected]
Street tyres first time :(
top stuff Bert, that mph is pretty decent mate!!!
Once you get a bit more practice, maybe some better tyres - if you can get ya 60ftr's down to 1.9 - 2.0. your mph is good for flat 12/low 12's...maybe a very high 11!
It was a while ago but my PB in my S13 is 10.65 @ 137mph, 1.96 60ft.
SR20DET, T88-34D 29psi with pump fuel and toluene mix.
Nissan Silvia on MT ET Street 255/50/16 Radials. Looking to break it again within the next couple of weeks!
PJ
  • 3 weeks later...
  • 3 weeks later...
WISD 5/8/09
R33 GTR V-spec
11.454 @ 131.25mph
60' @ 2.041
On 235x35x20 Nankang's (WHAT IS TRACTION....LOL) :(
Only my second visit in 18 months, was there for fun and had a ball. The car was loaded with tool box, big stereo, spare tyre, and a set of golf clubs....lol. Does this class as full street trim or what...lmao They kicked me off and said I need to get an ANDRA licence....more money...(does the spending ever stop, I think not!)
  • 3 weeks later...
  • 4 weeks later...
First time out,
R34 GTT, FMIC, Full exhaust, Toshi ecu tune, running 10.5psi
255/35 R18 Nangkangs=no grip.
13.701 @ 108.5mph
Its got more in it i just got to get it of the line and put the boost back on 12psi where its tuned to be.
Can't wait to go again.
  • 3 weeks later...
R32 gtr with $40 second hand Dunlop Le mans tyres WSID 11.8 @122.8MPH, had bad front axle tramp could be the shitty tyres i was using getting some Mickey Ts and should run a low low 11.hopefully. Stock rims 225x50x16. PFC,Pods, zorst and steel wheel turbos.
Next time should be better as i found out even with AWD shitty tyres will let you down. :)
  • 1 month later...
12.8 first time out to eastern creek...
trap was 0.48
and 60ft 2.10
turbo hks 2835 pro s.
full street trim with 225/45/17 federal 595's.
going for more boost and a tune to hold boost uptop then hoping for early 12's.
Edited by allthewaytotheskyline
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
