  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
holy crap, 1.57 sixty foot is real nice!!! WIsh our car would run that :(
You need more power now as its not really going to go much faster than that :(
i'm on toyo TQs drag radials(street legal i drive car from home to the track on them) and could go faster but am changing to second before the 60ft mark
have gone high 125mph 3 times on 18s in a full wieght car with amps and a sub. Air con stopped working so it came out ( firewall forward ), sound deading came out at the same time and so did 2 of the 3 amps and the sub and still can't match the 125mph :rant:
i only need to go .14 of a second faster then i'm done, if i can get back to the 125mph i should nearly be there
  • 3 weeks later...
Sydney Dragway at our SAU-NSW Drag Day.
60ft of 1.814sec
13.817 @ 95.23mph (153.27km/h)
GReddy Profec B spec 2 set at 12psi, return-feed FMIC, PowerFC, full exhaust, R32 GT-R manual conversion. Running Federal 595 at each corner, 245/45/18.
Didn't check tyre pressures, didn't remove anything from the car, didn't do any prep work at all. Car weighs roughly 1750kgs (forgot to check the weighbridge reading).
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
