actually ur wrong, i can c the constuction for the albury bypass which started 8 months ago
also the epping bypass is in there also :wub:
I can see houses in estates around me that are being built around the year old mark
  • Replies 82
some places dont work cause they havnt been mappd yet, id be more worried about there being satalites in space that can zoom in on your nipples
they have been there since the 70's dude.. the latest CIA KH-11 keyhole satellites have crazy resolutions.. and the NSA signals intelligence satellites capture all sorts of radio transmissions :D
Read this - http://www.space.com/SpaceReportersNetwork...ats_022202.html
Google Earth rocks...... We use it to spy good fishing spots creeks you can't ever seem to find when walking
through mangroves n stuff.
But as far as its updated i reckon its about year behind in the N.T which is odd because i mean we have so
much to see n all.... Funny how the creeks i want to fish are generally covered with clouds when i look for them i reckon my wife works for them and covers the spots i talk about.
Can you even look at your house? Last time i looked it was all blurred from around your place down to around Albert Park. My place and work were in the blurred section.
Yep. You can even see into the pool.
para u mean the Burj Al Arab?
its really a long way away from the airport so they should have built it closer to town. maybe its closer to snobsville (if there is such a thing over there)
best it could do was this:
Pretty sure that's the hotel with its own private highway staright from the airport. Isn't that where it got its 7 star rating from?
Adrian
the 7 star isnt acutally an offical rating... its just a marketing gimic. Not to take anything away from the hotel which is definately one of the best in the world. But the rating system isnt exactly a standardised one.
Ive got a video of Andre Agissi playing tennis in the court in the sky and launches balls off of it
I would be thinking meteorite shower if i were on the beach :D
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
