No it needs a manifold change but the STD one is total crap
any way. The turbo is a PER4MANZ design so the model
numbers are not important. This turbo has made 620RWHP
on a GTR with no more lag than STD GTR turbos.
Cost is about $6000 inc Turbo-gate-manifold and fitting,
and wont have the thrust wear problems that the
trust turbo has.
Any Turbo that uses the nasty RB25 manifold in a high power
application must be avoided, only good for mild power out
put.
https://www.sau.com.au/forums/topic/11157-trust-turbos/#findComment-186040
Rob,
I agree with Steve, the stock exhaust manifold design is dreadful, and whatever turbo you put on this should be removed. Plus if you want decent power then an external wastegate is the only way to go, most turbo's over 400hp only come in an external wastegate format.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11157-trust-turbos/#findComment-186103
Maybe you should do a bit more research on these cause they are so different...
Trust turbos as well as any other come in various sizes trims hp ratings, Rob a TD06 on your car may be a bit laggy, depending on exhaust size.
Ex wastegate New manifold Dump, intake pipes, new oil and water lines
hhmm...heaps of easier options mate
https://www.sau.com.au/forums/topic/11157-trust-turbos/#findComment-186127
It's not a cheap exercise by the time your finished, and determining the effect of the turbo on the car can be quite difficult. The best option is to get taken for a drive in a similar car to yours with the turbo done, then you can determin whether it is too laggy, enought power etc.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11157-trust-turbos/#findComment-186170
HKS get the turbos from garret.
HKS have their own build spec. combo's that they put together from Garret parts.
These are what HKS believe offer the best performance for what ever goal HKS had in mind.
The same goals they have may not be yours however. So a turbo builder that has been around a while may have more to offer you in terms of a purpose built turbo for your needs.
https://www.sau.com.au/forums/topic/11157-trust-turbos/#findComment-186582
Originally posted by rob77
So what turbo have you got macka? and what are you doing paul? when will you have new turbo?
Ive put a T4 compressor and wheel on the original R33 Original Ex housing with a T4 wheel
However still playing with it as i need a different comp wheel for smooth driveability and an external wastegate
Ill get there in 1 day
My opinion is the HKS have newer technological efficient turbos which spool perhaps slightly quicker due to design to wheels.
I would Jump at the chance however to own a Ballbearing GT series Garrett turbo and still get full spool by under 3500rpm
https://www.sau.com.au/forums/topic/11157-trust-turbos/#findComment-186654
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
