Hello people, i'm new to this forums. I'm from Ballina and Lismore from Northern Eastern NSW. Where i am, both cities had grown so fast and bigger as i seen since 1995. Ballina had grow nearly a same rate as Gold Coast and there are so many developments of highrises and buildings. New town plans and new duplex sites had started in Ballina Shire since 2004. Lennox Head (north of Ballina) had grew 10,000 since it first settlement and it starting to join Ballina's urban land. I guessed Ballina population for 2006; Ballina city: 29,000 and Ballina Shire: 49,000.
Lismore is very big city in northern nsw area, new commerical bussinesses and housing developments there.
More info soon.
Any Comments?
Matt Townsend
https://www.sau.com.au/forums/topic/112015-australias-fastest-growing-demand/
  • Replies 79
LOL gotta love those storms up there. LOLMAO
Last year we had tornado like storm went thru, there was reports of wind damage near Nimbin. Some ppl thought it caused by a tornado! Couple years ago, there was a tornado reported at Nimbin, feel weird if naked girls hiding in the bush!
Matt
Any Information to back up the claim that ballinas growth rate was similar to the Gold Coast???
If it wasnt for protected land GoldCoast would be a part of Brisbane by now
and population numbers were alot more than 80000
I found something.
Population & Growth. The Gold Coast is currently the fastest growing ... The attraction this region holds will ensure a faster growth rate of at least 3.7%
and Ballina:
The resident population of Ballina Shire is approaching 40 000 people in 2003......population growth rate was 4.3%
Found that in google search.
Matt
its a beautiful little town and its growing fast but damnnn i'm bored of my ass cose theres absolutely nothing to do here, so mite as well advertise it so more people can come here and make my boring life more fun
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
