Hi everyone,
I'm ordering stock for my new e-business that I am in the process of setting up. To help lower costs of importing the first lot of stock I am putting the word out for anyone that wants to be involved in a group purchase.
The supplier is in Taiwan. The pricing listed below is in Australia. I've calculated the costs of Import duty and GST into the pricing, so items will cost what is listed plus freight to your door(see below).
So, here's what is available and its price landed here in australia.
INTAKE PLENUMS
RB20 Intake Manifold or RB25 Intake Manifold $502.49
RB26 Single TB conversion Intake Manifold $502.49
RB26 Greddy Style Intake Manifold "Polished" $689.69
SR20DET Intake Manifold "Polished" $541.90
Available with throttle body flanges for standard, 73, 80,90 and 100mm.
Throttle bodies (Veilside Replica's)
73mm Throttle Body $345.46
80mm Throttle Body $376.87
90mm Throttle Body $408.27
100mm Throttle Body $492.02
Available in either blue anodised or clear anodised finishes.
FREIGHT
Freight to anywhere in australia will have to be calulated but I can say that small items <3kg = $11.60 overnight freight. <5kg will be $16.10 for overnight freight also. Larger items such as plenums will be sent by mail and should be less than $30.
To participate in this group buy, email me and tell me what you are interested in purchasing. I'll be maintaining a register of who's buying what. Then once I receive the volume pricing i'll email everyone back what the final delivery price will be for what they want.
So the details I'll need are:
Name:
Shipping Address: (Preferably a place of business so packages can be signed for)
Phone or Mobile:
Email Address:
Item(s) you are interested in:
Once I've got your details I'll keep you up to date and give you a freight quote. This group buy will close on the 17th of April (2 weeks). At which time I'll make contact with those that have expressed interest. Product will arrive in Australia by the 8th of May at the latest.
Thanks,
Ian Swinkels.
Mobile: 0434 147 478 or 0740527220 (business hours)
[email protected] (this address is SPAM filtered, so if your mail bounces try [email protected])
Edited by GTST4Newbie
  • Replies 41
I wouldn't be game to compare the two. There is no doubt that a Sub Zero plenum is awesome quality, hand made and australian quality parts, but it all comes down to what you want to spend.
The GTR style single throttle body plenums RRP for about $918 AUD in new zealand, and the GREDDY style ones RRP for about $915. So its about $300 cheaper for one of these taiwan assembled units.
In the end performance comes down to flow. So provided its match ported to your head/throttle bodies it will do well. Weather it be a sub zero plenum or any other one, it will still require this kind of work to be performed if your chasing serious ponies!
Out of conisidence i'm ordering a Sub zero plenum tomorrow myself!
Yes Kyle, the plenums use the standard intake runners but are cut off and have plenums attached. Each plenum runner has a trumpet at the top and are match ported to the runners after welding.
Because it uses a factory manifold its a guaranteed direct bolt on affair, with the exception fo having to re-run your vacuum hoses and relocate the throttle, and intercooler plumbing.
33SOM... Adapters for the standard throttle body? You mean a plenum for the standard throttle body? If thats the case then yes the plenums are available with throttle body flanges for throttles from stock to 100mm in all type of engines. 80mm is definatly the best way to go for all round tunability and room for 500hp easy.
Stock R32/R33 ones become a restriction around the 280-300 mark although you can still push a lot more thru them there is power to be had by increasing the size of the TB.
Sub Zero have moved and renamed their operation to Ferral performance... They still make plenums for around the $1000-1200 mark too depending on what your chasing.
Proven... not by me. But i'm sure someone out there is using them.
They are the same as the ones sold at ...
http://www.japaneseperformanceparts.com
I'll be buying from their wholesaler...
PROBLEM.... RB25 intake runners are in tight demand... and as a result they can't supply RB25 plenums unless I ship them intake runners first.
I'll be seeing if I can cut a deal with a some of the importers to get a heap of them for the right price. I'll update you all with my progress, but for the moment i'll have to say RB25 plenums aren't available at present.
CHeers,
Ian
The RB26 Single throttlebody manifold does not fit needing welding and machining to get them close.
I tryed and gave up as the end result was going to be very sub standard.Used the throttlebody on a Greddy manifold also with poor results with 1300rpm being the lowest idle speed i could get.
Dam thats not good at all! With the throttle body did you try starting the car and jaming a rag in the intake (or covering it with your hand) to eliminate the possaibility of a vacuum leak elsewhere? I've been told by the suppliers that they have a ball bearing supported shaft that is sealed?
Did you get yours from japaneseperformanceparts in NZ?
Hi Everyone,
Here is another picture of the RB20 plenum from a diferent angle. The supplier sent me a bunch more pictures but this was the only one worth looking at. When I ask for pictures of inside the plenum I think things are getting lost on translation...
They have 3 vacuum connections and also a connection for the brake booster. I can't tell if there is a place for the idle control valve at this stage yet. And again due to language lost in translation I can't get a clear response from the supplier... :S Worst case is that a small flange would need to be welded onto each plenum. On the bright side of this, you can put it anywhere you want, so you can mount it under the plenum so its not visable.
Also, the group buy is being extended until the 19th (2 days extra) due to a 1 week holiday that everyone seems to be taking in taiwan.
There has been a fair amount of interest in the group buy, enough that it will definatly be going ahead.
The lack of RB25 plenums is an issue, but i'm still investigating a work around and possibly importing the plenums allowing you to get them welded and match ported locally.
I'll be in touch with all people that made an enquiry in 5-7 days prior to placing the order on the 19th.
Cheers,
Ian Swinkels.
very interested in one for a 20, provided we can get pics of the inside, also something that concerns me is that the rb20 one seems to be very similer to a gtr manifold, in terms of short intake runners, which has been tried and tested and you loose low down torque and power pretty much everyware, one of the nice things about the plazaman plenium is they bolt onto the original lower half of the manifold :bomb_ie:, as there any way we can get some kinda dyno charts?
very interested in one for a 20, provided we can get pics of the inside, also something that concerns me is that the rb20 one seems to be very similer to a gtr manifold, in terms of short intake runners, which has been tried and tested and you loose low down torque and power pretty much everyware, one of the nice things about the plazaman plenium is they bolt onto the original lower half of the manifold :), as there any way we can get some kinda dyno charts?
No I can't get pics of the inside. I will take some personally when the first shipment arrives.
Yes the total intake runner lenght is less with these plenums so in theory you loose some off boost torque, but it makes no diference when they are on boost. The intate runners do have trumpets on top of them.
No dyno info at this stage, but i'm planning on doing a before and after 16lb run on my car when I get one for it, so i'll post info then. Frankly i'm not putting it on to improve performance. I just hate the stock plenum and the cross over pipe you have to run if you have a frount mount IC.
I'm on holidays in darwin at the moment but i'm still in email contact. I'll be trying to keep people informed. When i'm back home monday week i'll be placing the order shortly there after making contact with everyone, confirming details again etc. Its still some public holiday in Taiwan as well so they aren't replying to email till the 23rd.
Cheers,
Ian Swinkels.
Group Buy is closed. Thanks to everyone thats involved. I've emailed you all now, but if for some reason you didn't get my email let me know. The order is being placed this Wednesday. Parts arrive in 6-14 days.
Cheers,
Ian Swinkels.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
