;) Hiya's all, after a little bit of info from you'se all!
My Stagea is due for a 5000km oil change, etc. Its done just under 5000kms since I bought it, but in that time Ive had a couple of dyno sessions, etc.
Id like to drop the oil, change it, and do the oil filter as well. Thats going to happen tomorrow (fri 7/4/6) when my castor bushes are installed and the suspn work retightened 9after the initial 100km rundown).
What oil would you all suggest? Im thinking Mobil 1? Also, is the oil filter the same as a standrad R33 one, and if thats the case, does anyone know the genuine Nissan part number?
Also, what else should be 'touched' at a basic 5000km oil change?
Cheers, Brendan
https://www.sau.com.au/forums/topic/112563-stagea-5000km-service/
  • Replies 79
Posted Images
Hi Brendan, we only use Castrol lubricants in all the cars, so my Stagea has Edge 10W60 in it. At 5,000 k's I do the usual fluids check, radiator, auto trans, washer bottle fill, brake fluid, tyre pressures, ATTESA reservoir, all the globes (there is always one out somewhere, usually dash), brake pad thickness and brake hose condition. Then I do a quick whip around with the spanners and check the tightness of all of the non standard stuff. Lastly I make sure the wheel nuts can be removed by the female drivers (that's not more than 70 ft/lbs on the tension wrench).
:O cheers :D
PS; I also check the toe and camber settings, because I can ;)
Edited by Sydneykid
:O cheers :D
LOL :)
Ta mate! Thanks for that advice.
I know the globes are all good (besides one in the A/C dash area), and the tyres are 2 weeks old, so thats all good too. I'll ask him to have a quick look at the fluids of the car - cheers. With the toe and camber settings I'll leave that until I have a wheel alignment!
Query: is the castrol Edge better than mobile 1? I thought Mobile 1 was premium oil......... I used to use it in my V8 BT1 commodore.
Brendan
PS Gary - Got to say, Im a fan of the suspension components I bought from you - thank you very much again for all of that. The Bilstein shocks are a touch hard, but nice nonetheless; they have done 30kms now! And Im happy that Im using the standard springs. Heights are 370mm all round, so I might drop 1 circlip at each corner, eventually. The standard shocks were weeping, and basically rooted. Glad I did the group buy.
A touch hard, but f**k do they handle in twisty stuff! ;)
I use castrol GTX3 at the moment, but my next change will be with Synthetic R, it might be 3 times the price, but i do give it a pretty hard life, might as well spend that extra $10 a month and give her the best, so i can treat her like i do :thumbsup:
Aaahhh good ol Mobil 1. I remember my bike riding days in the mid 80's when we used Mobil 1 'cause a racer friend swore by it and it cost a little under $30 for 4L. But then good oil in those days was around $10-15. Then everyone else found out Mobil 1 was good, then the price went up to $40. Then $45. Stopped buying it then as a personal protest at the price. The rest is history and $30 looks cheap.
Bob Romano has seen a 30Hp increase on the dyno in large (old) V8s just with an oil change from basic oil to Mobil 1.
Brendon, The oil filter part no. is elsewhere on a thread. I believe RYCO is 145A.
I recently used a Fleetguard SF 3434 filter. $9, available from any industrial filter shop - trucking good quality. Oil was Nulon 10W40 cheap for 6L - you'll need 5 min.
cheers
Wazza
P.S Good idea to hose the subframe around the filter before pulling it off as I dont know of anyway you can avoid spilling some out of the filter when you undo it.
P.P.S The crush washer you will need for the sump plug is only about 12-13mm in dia.
Edited by 3intheBack
  • 2 months later...
Hi Guys,
Just picked up my stagea and doing the once over.... first thing I have notcied is that the 4wd fluid in the back wagon section of the car is really low... i have some Castrol TQ Dexron III auto trans fluid... can anyone tell me if that suitable for the 4wd fluid? Would like to know so I can top it up????
Cheers
Hi Guys,
Cheers
http://www.skylinesaustralia.com/forums/in...opic=61606&st=0
see page 1; reading that Id suggest that yeah your fluid would be suitable - I better check mine too!
or see alexcim's setup: http://www.skylinesaustralia.com/forums/in...117723&hl=fluid
Edited by Tangles
I have used 'Penrite' oils for the last 10 years. I used it when I raced my RX2 as a club car for 4 years, that was a good test. Never had a need to change brands. Since owning the stagea I have used HPR 10 eng. oil. Have been quoted MGO75 for Attessa (am going to double check), SIN 75 for the diffs. I fitted DC tranny cooler 2day and topped up with SIN ATF.
  • 1 month later...
:D Hiya's all, after a little bit of info from you'se all!
Cheers, Brendan
I use Mobil synbthetics 15w/50. Castrol oils and mobil oils works very different from each other. And im not going to disscuss this over the forum w/o getting shot myself from people. All in all Castrol do not make their own oils :( . That infor is from years ago the sub contract it out. So that tells you all. And thats the only thing im prepared to say.
I have been using Mobil 1 synthetics for all my cars. My lancruiser even uses Mobil Super S anf now its clocking 200k on the dial and still smooth as silk.
Tnangles we can discuss this over MSN if you want later in the afternoon after i get back or if not tommorow.
hey stageagirl have a look at the groupbuy section for the quick change oil valve and you won't need to find/buy a crush washer ever again!!!
i think i worked out how to put in a link ? have a look here and see what ya reckon?
oh and by the way i agree with you on the ban stupid people, not dogs bit!
http://www.skylinesaustralia.com/forums/in...127757&st=0
Edited by oxford1327
I use Mobil synbthetics 15w/50. Castrol oils and mobil oils works very different from each other. And im not going to disscuss this over the forum w/o getting shot myself from people. All in all Castrol do not make their own oils :pirate: . That infor is from years ago the sub contract it out. So that tells you all. And thats the only thing im prepared to say.
Fair enough - heard that myself on the grapevine too.
We used Penrite 5-60w oil.... seems the goods. Might go back to Mobile 1 when I do a highflow turbo, either that or Castrol Edge or the current Penrite stuff. Plenty of time tho, only do around 8000km per year. By the next oil change I hope to have one of the quick release valves too Ox!
Mobil engine oil is able to absorb the carbon deposits from the engine keep the engine clean. thats why mobil oil wil always be black and gooy and castrol will be clean.
OOOOOOOOHHHHHHHHHHHHH Yeah.
you should have seen it ! very very black and very gluggy.............. changed right on time. Theres no way Id allow oils to sit in a Rb engine for 10000kms now, no way. 5000km oil changes for sure.
my car has just about ticked over 65,000kms... i do the above mentioned services every 5000ks, but when should i be doing major services such as belts etc? to be honest this is the first car ive had that im concerned about servicing, just because theres a lot more that can go wrong, and a lot more expense if you let it go.
What should i be booking it in for, and when?
Ive noticed it sometimes has dramas (often, nearly) with idling, and driving around carparks, that the revs like to drop right down to the point where powersteering goes real tight, and it takes a bit to pick up when i feed it a little throttle...
stock BOV over here. my engine is factory. DID have a boost guage, just for about a month, but have since removed and returned vac to standard. no pod.
So it beats me! thinking it may be a busted vac line somewhere, but can see anything...
I have a sticker under the bonnet that tells me about belts and the km's they should be changed. Timing belt needs to be done at 100,000kms :D I'll start saving now :P My car has 70,000kms... probably needs a timing belt now eh :D
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
