How much oil do I need to put in the engine when I change the oil? I bought Motul 8100 X-cess 5w40.
I have a Series 2 C34 Stagea with an RB25DET NEO engine.
I remember my S13 used to take about 3.7 litres, so I guessing it is probably around over the 4 litre mark?
4.3 then check it.
Motul is trash, i just used it, motor is noisey, never use it again.... only reason it has good SAU feedback is the one of the guys is mates with the rep, mechanic's have said it has done shit in other studys.
Charles and I swear by Fuchs, so get it in ya!
Motor is cleaner, smoother, quieter etc. Lasts longer from Chuckies lab tests and my touch tests.
  • Replies 79
Posted Images
Lot of top drag cars and drifters use Motul.
I am now using Castrol 10W- 60 (synthetic).
how good is marketing. If these same people were beating their wives are bashing their kids, would you do it?
Castrol and Motul are trash.
I use Fuchs 10w30 when ever I can get it.
Motor is noiser since using motul this fill, doesnt feel as smooth
Edited by Ryan1600
hang on ryan, motul and castrol are trash. that is a big call.
which oil grades and types are you talking about?
there are lower spec and higher spec oils in every range to suit an application or get it down to a price.
Edited by wolverine
LOL.
I noticed that you put Motul 8100 in and had a bad experience... as did I. It stayed in for almost 2 weeks, the engine was much harsher and noisier. When I put the engine cleaner through, a large glob of sludge came out the drain hole. Will never use 8100 again.
I don't touch Castrol either. Not again.
I have tried a heap of different oils in my car (RP, Mobil1, Amsoil, Shell Helix Ultra, SIN, Castrol Edge, Nulon etc) but for the last 55,000kms I have only used Motul 300v Chrono (10W40).
Engine has greater response, is much more "rev-happy" and is smooth as silk AND it still feels great at 10,000kms when I do my change.
Yeah it costs a bit more, but I am happy to pay for quality. Especially when it comes to engine oil.
Happy to view these tests of Fuchs that you speak of, just point me to 'em!
did you think maybe the solvents and other additives in the motul oil maybe loosened the build up/varnish from other oils, and then the flush finally got it all out?? :)
if it sounds harsh and noisier, its entirely possible the oil is too light for the engine.
for me, ive never had a problem with castrol formula R (now edge sport) 5w30 in my SR20s and honda K24A. i run a flush before every oil change too!
waht was the prob you had with castrol??
Nope. It was the cleaner that got it out for sure.
I used the Amsoil cleaner (which is pretty harsh) when I drained the 8100.
The 8100 is a 5w40 I believe. Was much noisier than the Mobil1 (0w50) and noisier than Nissan's 7.5w30 that I had in there.
Felt quite loose (too loose) and the engine seemed to take a bit more effort to rev, but nowhere near the Penrite SIN which felt like it was suffocating my poor Stag (only lasted a week - ~800kms).
nulon is something i would like to try.
i have tried both of the lower motuls, i use the low end fuchs, chuckie did lab tests on his.
my motor had castrol for 40k km from the previous owner, the fuchs cleaned it out, freed it up a bit, oil came out cleaner and cleaner, got better economey etc.
are you still using the amsoil cleaner? i use nulons oil flush
now question, have you tried nulons range of oils?? i did once in my S15 SR20, but i cant remember why i stopped using it.......
Used the Motul engine flush every 2nd oil change since I changed to the 300v.
Only use the Amsoil flush when the engine felt crap after some average oil. It is pretty harsh stuff so I don't like to use it all the time.
Nulon, yes I used it once. It was my 2nd oil change (Nissan oil was the first with a major service & check).
Can't really remember much difference in feel over the Nissan oil, so I guess it was not a stand out either negatively or positively.
I WILL be putting it in my wife's Magna next weekend though after an engine flush, so will be able to compare it with the standard Penrite stuff that was used :) when her car was last serviced (not by me).
When you get your GTR Ryan, may I suggest the Motul 300v with a good filter? K&N, Versupeed?
Ryco or OEM Nissan filters,
With probably just a higher quality(depends how much it is thrashed by me) and thicker Fuchs.
Nissan 'Special Blend' FTW
:P
(Not fully synthetic, but the price is right)
I used to use Castrol Formula R in my Z, can't even remember what's in the Skyline (could be Special Blend in there too...). With all the extra expenses that life thorws at you, I just couldn't justify $60+ per change in the Z when it was a daily-driver. I shall be re-evaluating my choice for that particular car once I get my rather expensive new L28ET installed...
Mobil 1 also got a bit of use - but again, the Special Blend even changed more frequently, was a more economical buy.
Great globs of crap are certainly not unheard of coming out of JDM engines. And I certainly noticed the engine & oil temp decrease slightly when I did start using the Formula R in the old L-series (and no real increase in rattle-factor with the thinner oil)
Genuine Nissan oil filters, and thermostatically-controlled oil coolers are also a good thing.
Not sure if you have one, but on my radiator support i have a sticker saying "E/O-4.2ltrs - O/F-.3ltrs"
Simply means - Engine Oil - 4.2 litres, Oil Filter - .3ltrs
So 4.5ltrs for a full top up.
Also I do have to say, my neo6 is quiet as. It has over 160,000 k's on it, and with the motul feels so crisp. Also i am getting 600k's till the fuel light comes on. I can not fault this oil. Even changing @10,000k's the oil has excellent lubricity. You can feel it between your fingers.
I had a look for that sticker on my radiator support but it wasn't there.
In the end my Stagea took 4.5ltrs of Motul 8100 X-Cess. Hopefully it improves the fuel economy.
I always used Motul 4100 turbolight in my CA18DET S13 & it ran like a charm, however each to their own. I haven't had a problem with Motul as yet so I'll keep on using it until I do have a drama.
  • 2 months later...
LOL.
Ghey-est "test" ever.
how so?
if you buy oil for power, it's probably the best test you're gonna get. i personally buy oil for the protective qualities, not power, but we're all different.
i went to my regular place for oil etc on the weekend, and the $45 5L oil that i used to get is now $75!!!!!!! wtf is with the prices???
which oil was that?
Edited by pyro-ns
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
