How much oil do I need to put in the engine when I change the oil? I bought Motul 8100 X-cess 5w40.
I have a Series 2 C34 Stagea with an RB25DET NEO engine.
I remember my S13 used to take about 3.7 litres, so I guessing it is probably around over the 4 litre mark?
4.3 then check it.
Motul is trash, i just used it, motor is noisey, never use it again.... only reason it has good SAU feedback is the one of the guys is mates with the rep, mechanic's have said it has done shit in other studys.
Charles and I swear by Fuchs, so get it in ya!
Motor is cleaner, smoother, quieter etc. Lasts longer from Chuckies lab tests and my touch tests.
  • Replies 79
Posted Images
Lot of top drag cars and drifters use Motul.
I am now using Castrol 10W- 60 (synthetic).
how good is marketing. If these same people were beating their wives are bashing their kids, would you do it?
Castrol and Motul are trash.
I use Fuchs 10w30 when ever I can get it.
Motor is noiser since using motul this fill, doesnt feel as smooth
Edited by Ryan1600
hang on ryan, motul and castrol are trash. that is a big call.
which oil grades and types are you talking about?
there are lower spec and higher spec oils in every range to suit an application or get it down to a price.
Edited by wolverine
LOL.
I noticed that you put Motul 8100 in and had a bad experience... as did I. It stayed in for almost 2 weeks, the engine was much harsher and noisier. When I put the engine cleaner through, a large glob of sludge came out the drain hole. Will never use 8100 again.
I don't touch Castrol either. Not again.
I have tried a heap of different oils in my car (RP, Mobil1, Amsoil, Shell Helix Ultra, SIN, Castrol Edge, Nulon etc) but for the last 55,000kms I have only used Motul 300v Chrono (10W40).
Engine has greater response, is much more "rev-happy" and is smooth as silk AND it still feels great at 10,000kms when I do my change.
Yeah it costs a bit more, but I am happy to pay for quality. Especially when it comes to engine oil.
Happy to view these tests of Fuchs that you speak of, just point me to 'em!
did you think maybe the solvents and other additives in the motul oil maybe loosened the build up/varnish from other oils, and then the flush finally got it all out?? :)
if it sounds harsh and noisier, its entirely possible the oil is too light for the engine.
for me, ive never had a problem with castrol formula R (now edge sport) 5w30 in my SR20s and honda K24A. i run a flush before every oil change too!
waht was the prob you had with castrol??
Nope. It was the cleaner that got it out for sure.
I used the Amsoil cleaner (which is pretty harsh) when I drained the 8100.
The 8100 is a 5w40 I believe. Was much noisier than the Mobil1 (0w50) and noisier than Nissan's 7.5w30 that I had in there.
Felt quite loose (too loose) and the engine seemed to take a bit more effort to rev, but nowhere near the Penrite SIN which felt like it was suffocating my poor Stag (only lasted a week - ~800kms).
nulon is something i would like to try.
i have tried both of the lower motuls, i use the low end fuchs, chuckie did lab tests on his.
my motor had castrol for 40k km from the previous owner, the fuchs cleaned it out, freed it up a bit, oil came out cleaner and cleaner, got better economey etc.
are you still using the amsoil cleaner? i use nulons oil flush
now question, have you tried nulons range of oils?? i did once in my S15 SR20, but i cant remember why i stopped using it.......
Used the Motul engine flush every 2nd oil change since I changed to the 300v.
Only use the Amsoil flush when the engine felt crap after some average oil. It is pretty harsh stuff so I don't like to use it all the time.
Nulon, yes I used it once. It was my 2nd oil change (Nissan oil was the first with a major service & check).
Can't really remember much difference in feel over the Nissan oil, so I guess it was not a stand out either negatively or positively.
I WILL be putting it in my wife's Magna next weekend though after an engine flush, so will be able to compare it with the standard Penrite stuff that was used :) when her car was last serviced (not by me).
When you get your GTR Ryan, may I suggest the Motul 300v with a good filter? K&N, Versupeed?
Ryco or OEM Nissan filters,
With probably just a higher quality(depends how much it is thrashed by me) and thicker Fuchs.
Nissan 'Special Blend' FTW
:P
(Not fully synthetic, but the price is right)
I used to use Castrol Formula R in my Z, can't even remember what's in the Skyline (could be Special Blend in there too...). With all the extra expenses that life thorws at you, I just couldn't justify $60+ per change in the Z when it was a daily-driver. I shall be re-evaluating my choice for that particular car once I get my rather expensive new L28ET installed...
Mobil 1 also got a bit of use - but again, the Special Blend even changed more frequently, was a more economical buy.
Great globs of crap are certainly not unheard of coming out of JDM engines. And I certainly noticed the engine & oil temp decrease slightly when I did start using the Formula R in the old L-series (and no real increase in rattle-factor with the thinner oil)
Genuine Nissan oil filters, and thermostatically-controlled oil coolers are also a good thing.
Not sure if you have one, but on my radiator support i have a sticker saying "E/O-4.2ltrs - O/F-.3ltrs"
Simply means - Engine Oil - 4.2 litres, Oil Filter - .3ltrs
So 4.5ltrs for a full top up.
Also I do have to say, my neo6 is quiet as. It has over 160,000 k's on it, and with the motul feels so crisp. Also i am getting 600k's till the fuel light comes on. I can not fault this oil. Even changing @10,000k's the oil has excellent lubricity. You can feel it between your fingers.
I had a look for that sticker on my radiator support but it wasn't there.
In the end my Stagea took 4.5ltrs of Motul 8100 X-Cess. Hopefully it improves the fuel economy.
I always used Motul 4100 turbolight in my CA18DET S13 & it ran like a charm, however each to their own. I haven't had a problem with Motul as yet so I'll keep on using it until I do have a drama.
  • 2 months later...
LOL.
Ghey-est "test" ever.
how so?
if you buy oil for power, it's probably the best test you're gonna get. i personally buy oil for the protective qualities, not power, but we're all different.
i went to my regular place for oil etc on the weekend, and the $45 5L oil that i used to get is now $75!!!!!!! wtf is with the prices???
which oil was that?
Edited by pyro-ns
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
