Some of you may know, some of you don't so here's the lowdown before the rumors start.
Ice Performance is going through a restructure.
Gerald and Nigel have been running Ice Performance over the last 3.5 years to build a strong and reputable name in the modified automotive industry. Together they built Victoria's fastest GTR, Australia's first 10 second GTR and countless other monsterous street machines.
Nigel has decided to part ways to start his own business in the automotive industry. The split is amicable and there are no ill feelings between any parties involved .
Business will be as usual at Ice Performance as Gerald will be running things on his own from now on. Servicing, modifying and upgrading of your car will still be conducted as usual.
In early to mid June though, Ice Performance will be installing some new equipment and remodelling the factory to also offer panel beating, spraying, body kit fitting and other cosmetic repair needs. More details about this as they come.
If people need to contact Nigel, he can still be contacted through the normal channels.
Gerald at Ice Performance can be contacted on 9512 7591 or 0414 359 888.
https://www.sau.com.au/forums/topic/113392-restrucuring-of-ice-performance/
"In early to mid June though, Ice Performance will be installing some new equipment and remodelling the factory to also offer panel beating, spraying, body kit fitting and other cosmetic repair needs. More details about this as they come."
about time a decent tuning shop did this.
Guys,
Nigel's new workshop will be called Racingline Motorsports. It will be located at 15 Bricket St Cheltenham. (Melways Ref 78 B10).
Racingline Motorsports will be open as of early May intime for the dyno day. Details of the dyno day can be found in the Vic events section.
Guys,
ya should have mentioned this in the dyno thread, otherwise it looks like any random shop holding a dynoday.
Guys,
Isn't that the ICE address, or was that number 28??
ah good good, i might actually get around to having the bodywork fixed...
... i understand that the split was amicable but wouldn't they now be in direct competition? or are they going to be offering different services or catering for different types of clients???
Differeny types of clients is my understanding.
Look, worst case, go chat to Nige & G and sort out who best stuits your needs.
Its amicable definately... i mean i like with G for gods sake and there is nothing sour at all
Nige will still be there until the end of April.
Yes, the Ice Performance website is still on it's way. Just waiting for our developer to do something about it :(
LEEWANG …………… next time I see you, I will ask you ……“What did the 5 fingers say to the face……………………..????? S L A P !!!!!!!! lol
I have asked Gerald etc several times to come back to me with any content for the site, he was always too busy. I even got Ross to come down with me to structure the site. We got the sitemap sorted more or less, but once again been waiting for content which never arrived. Asked a number of times but nothing happened.
Good luck to Niege with the new business and I hope Gerald keeps going as well as he has.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
