  • Replies 92
Hi guys I thought I should add a story that I have
Recently my car started losing oil pressure, It was fine on cold start but as you drove around the pressure dropped to almost nothing and I was using a heap of oil as well, I was thinking the worst, till I read TO4GTRs thread about keeping that RB alive.
I had Motul 10w40 turbo light in the car and as the temperature built the oil simply couldnt cope and broke down becoming too thin for the pump to push properly
I changed to penrite 5w60 and problem solved so thnaks to dave for pointing me in the right direction, the penrite is about $20 cheaper too!
  • 4 years later...
What are peoples thoughts on PENRITE 5w60 Fully Syn?
I just ordered mine $120 for 5L. Guy at Supercheap showed me this:
http://royalpurple.com.au/article_images/oil_test_article.pdf?ptl=hot_rod_article.php?ptl=articles_oil_supplement.php
PDF file showing a test run by a magazine. Unsure whether to believe it or not(could be a big marketing ploy). Motul didnt do too well in that test, and neither did Mobil/Elf..
For anyone wanting more info it's all covered in the oils sticky whistling.gif
I used motul 8100 xcess, and loved it, until sougi s6000 came into my life. But that's dead and gone now sadly. The nulon "fully synth" was pretty good for a grade 3, cost a bit though when 4100 turbolight is cheaper.
Not sure if it's the same for gtr's, I'd imagine it is, but 10w40 is usually about right for aussie conditions with the normal number of kms on it.
There are a few conditions that have to be met by the viscosity of the oil, and it's all compromises:
-On start up it has to be thin enough to be pumped quickly to moving parts, yet thick enough to provide decent protection when there.
-You want it to be thick to provide decent protection for valves and cylinders, but thin enough to drain from the head to the sump properly.
They're the two big ones. 10w40 is usually accepted to be adequate for australia. The original nissan oil was 7.5w30, but many kms have been done since then and, more importantly, the weather conditions are different here.
How about Penrite Sin 5 (5W-60)?
I have a standard R32 GT-R, probably has like 120,000 km
Nissan recommend 7.5W - 30 in their books.
+ the R32 being engineered in the late 80's to early mid 90's, it would most probably be a Mineral Based engine oil.
I have used:
- Martini Racing 10W - 40, Full Synthetic = Very nice!
- Valvoline 20W - 50, Semi Synthetic = Bit too "thick" and car ran sluggish.
- Shell 15W - 50, Semi Synthetic = Was ok for the first 1000 kms then turn to shit.
- Mobil Synthetic S 10W - 40 (2000 X 2) Semi Synthetic = Best so far from what I have used and just before an oil change the car still runs well, once changed = Very smooth.
My mechanic has recommended Mobil Synthetic S and the car is running fine.
I think the Mobil has the closest viscosity to what the R32 GTR should run, but everyone has their own personal preference and recommendations.
Different cars will have different recommendations + if you car is modified (Mild to Heavy) and having internal mods done, you'd run a Full Synthetic as the engine will have different tolerances to stock and lightly modified cars.
Just changed my oil today. Oil pressure on cold start up is down to around 5bar(7bar before). I used to run Elf fully sun 15w50(I think). Im also using a Veruspeed Nismo filter as well.
I noticed the engine was more responsive. I guess I'll keep an eye on it.
EDIT - I used Penrite 5w60 Fully syn oil. Bloody exp - $130/5L.
Edited by Ultimategtr
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
