Greddy Timer, Position behind the centre console (can't see it from the front).
i.e. Wires straight from the back of the steering wheel -> behind console, seems stock. If ever need to get it hand just goes down and its right there :)
Ashtray is good -> many people i know in 32's have it positioned there and certain authorities haveny been able to find it ;)
Blitz Dual stage... sits above my left kneee cap.
dont cops see that? I have a Pivot digital speedo on my dash and first thing cops ask me "is that a turbo timer?"
I have a HKS turbo timer and its behind the carpet in the footwell
Underneath the steering wheel, behind the plastic facia - well out of sight (impossible to be seen); oh, and SWITCHED OFF - switched it off upon delivery of the car, didnt even know it had one until I went to fill up and the car continually ran while I was putting in petrol (just a tad dangerous me thinks).
WTF do ppl need a turbo timer for? Wank factor I reckon.
Tangles,
A turbo gets extreemley hot. Sometimes even glowing red.
Metal when it is hot should be cooled down gradually (on idle) not rapidley (turning car straight off).
Metal stretches and expands some what with heat and cooling it down to quick will make metal brittle, or crack, or worp.
Thats why my timer for example (apexi) is attached to the oxygen sensor. The more air that flows through it (eg. if your putting your foot down) the longer the automatic feature on the timer will keep the car on. I just set mine for a minimum of 30 sec and a max of 3 min, and the timer figures out how hard I have driven the car and sets accordingly.
Hope that helps
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
