Hey hows it going everyone,
wondering if anybody could help me, ive been given a blown standard R33 turbo and decided i want to rebuild it and put it on my skyline R33, but hi flowed and i wanted to find out what internals are the biggest and the best to use in producing the most power out of the turbo also if i should use ball bearing or roller bearing and if i should go double bladed also any other ideas thanks guys!
P.S would T4 or T66 blades fit in or could i go bigger and are they good ?
https://www.sau.com.au/forums/topic/113745-hi-flow/
those sort of wheels are way too large for the stock turbine housing. it sounds like the combo would yield a surge monster as the compressor side is just too large. the standard hiflow is good for about 260rwkw with cams so that should be plently. if you want more power then go for an off the shelf item instead of trying to make the hiflow "flow" more as it wont correctly, it could either surge its ass off, be laggy as all hell or not even make more power.
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2095883
Ive never seen a hi-flow make 260rwkw??
GCGs hi-flow seems to be the biggest and will make at max 240rwkw (rb25 not rb20), but generally expect around 220-230rwkw. You do pay for it though!!
Most hi-flows will get you around 20-30hp more atw and aren't worth their price tags from what ive seen!
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2095964
My GCG Hiflow has put out 249rwkw to date, hoping for more after exhaust manifold, oil cooler and a better dump pipe have been installed this week
EDIT: That is without cams to, PFC, 16psi, FMIC,Injectors, Pump, Greddy Plenum, Q45 Throttle, Dump / Exhaust / Pod etc.
Ill keep you updated with the figures it makes when i put the other stuff on, i have been told i can expect 370 / 380rwhp @ 20ish PSI
Edited by Got Boost?
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096152
Well im happy to stand corrected!
Very impressive figures, the first thing i thought was 16psi you have a few more psi to play with and then i read the end of ur post... lol
Generally ppl dont use Q45 and Greddy Plenum which would help free up air flows and make more hp which could explain your higher than 'average' figure.
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096174
Yeah i have noticed not to many people take the same path i did, i have heard that the hiflows can get up to 20-22psi, so once i get the other stuff fitted im hoping to push as much as i can get out of it (without putting anything at risk of death). I have been considering getting some cams and and an adjustable gear, this might help me get those figures a little bit higher again so im going to look into that tommorow :(
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096179
My combo is currently making 274rwkw@16psi with VG30 ext. housing, cams and head porting, on a Dyno Dynamics Dyno. I opted to stop there as my bottom end is still standard, in fact i lowered the boost a fraction to keep it at 260rwkw.
As nice as that sounds the turbo will probably not make your "expected" figure, as i beleive it will run past it's effiency range well before then. I would estimate a hi-flow combo is probably good for about 290rwkw, maybe 300 max. More boost=more heat=declining power line. These turbos were not designed to run such high psi, yes they have been upgraded, etc., but they are still just a small factory turbo. But hey, i wish you all the best.
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096269
watch the gcg highflows, had a fellow forum member buy one and bolted it on and found the wastegate mounting spot was wrong and the gate was open fulltime, meaning full boost. not very good at all, and coulda cost him a motor as well, not to mention the costs of reinstalling (over $400) and 5 days without a car as well.
isolated case i know but this still happens so check those actuators r closing correctly before u install them!!!
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096276
If the actuator/wastegate was "open" full time the turbo would not boost, thus no harm to the engine. Still a very stupid fault from a turbo manufacturer.
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096279
the wastegate was stuck open so i was hitting FB at 4500rpm. I was amazed others with the GCG said it was just as responsive as stock....mine wasnt :)
Its all fixed now, but the $200 i saved on the turbo, cost me $400 in the end to get a workshop to fix it. Kinda annoying as i would have really expected better from GCG. Good turbo regardless, but f**k...annoys the shit out of and my wallet.
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096467
Open wastegate= no boost , or very little boost .
Shut wastegate = unlimited boost, only limited by the turbo.
https://www.sau.com.au/forums/topic/113745-hi-flow/#findComment-2096473
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
