After a year of owning my R33 I finally sold it, I dont know what made me do it, it was mostly the fact that there were so many around. It was sad to see it roll away down the street but im sure the new owner will be happy with it!
The new beast will come soon, will put up pics when I get it :(
https://www.sau.com.au/forums/topic/113781-sold-the-beast/
  • Replies 47
awww what a shame
although depends what you're replacing it with?
https://www.sau.com.au/forums/topic/113781-sold-the-beast/#findComment-2096307
hahahah
INASNT - nah not even near what I spent on it, I got a decent market price. In other words the guy laughed off with a absolute BARGAIN!!!
No its a not a VL or any other shit box like that.
Evo 8 did someone say? I wish I could afford to buy one, but I hate borrowing money when not necessary!
braaaap brappp brappp................have I let the cat outta the bag?
https://www.sau.com.au/forums/topic/113781-sold-the-beast/#findComment-2097169
Nah its not a RX7. I like em, but even stock ones are expensive and not to mention 90 percent of them are dodgy and on there last legs. Ive beeen to see a couple and havent been impressed. On the other hand a nice S7/8 SP/Bathurst would be awesome, but thats R34 GTR money where talking about and I know which car Id rather have. Its not a Rx2 either.
braaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaapppppp.......flutter.
https://www.sau.com.au/forums/topic/113781-sold-the-beast/#findComment-2098160
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
