well i sold my r31 last week
so i was down a fun car
so after a few vb's a cunning plan was unleashed to the world
im a 31 man and i must say s13 are really camp... so i had to do something about it buy injecting some r31 love into the s13
ill update this as it goes with helpfully tips for the little dooers out there
anyway the plan
stage one
1992 s13 sr20de auto silvia (check the miss's was away for a week so she didnt mind me floogging her car)
stage two
drop a running rb30e into the silvia and rip some burnouts
stage 3
drop a gtr head onto the old girl and some f**k off 350 hp high mount tiwns
time frame is about one month so heres hoping it all goes well
runing progresss 10/4/06
stage two
picked up a manual conversion for a s13
this one dropped in no dramas
quick rundown of the parts
r32 gts crossmember
r31 rb30e engine
rb20 sump
rb30 power steering pump
r32 gtr radiator
gtr clutch
two thermo fans
modified bonnet
basically the engine is in and running
this week we will plumb it up and add a surge tank for stage three
the engine does stick out of the bonnet a fair bit but this shouldnt be an issue when the gtr head is on
sorry only got a few picks
im hoping it rips a mean skid
stage one is complete
well stage one is complete i must say the thing is an animal!!!!!!!!!
bp ultimate and heaps of timming = great burnouts
picks of the bonnet
looks photochoped hey but she is in there
almost a factory install if you ask me
thankyou super kyle (r31 mechanic in newcastle)
this one shows how high it gets
this is why we need a bonnet scoupe
thermos on the front cause there is only an inch to the radiator
sexual chocolate
some wank in the interior (working out how the tach worked was going to be a killer
https://www.sau.com.au/forums/topic/113833-crackpot-idea-number-52-by-fatz/
  • Replies 43
I like it... Find the biggest capacity nissan 6, then turbocharge it, then put it into the lighest chassis possible. :thumbsup: should be a lot of fun and tail happy.
Hope the weight balance is OK.
you are a champion for inventing such a car...
Wasnt some dude in NZ doing that same thing?
Either way, you are my hero, I love you. Please keep things updated. Might be handy when I sometime get the money and time to get one in the cef.
weight is fine
ill be taking it to the sau circuit day and thrashing it hard to get a feel for the handelling
just need to tee up some shocks
currently has kyb ones with stock springs (lol the suspension level raised with the new engine... work that shit out)
if you could ever get that car to hook up and go you would have a supra/bike killer on your hands...
awesome work, rb swaps into s chassis cars are loads of fun.
also check out www.lsauto.com for a drop in tach that reads the 6cyl signal or grab a r32 gauge cluster and with a touch of trimming the r32 tacho fits into the s13 cluster.
as for the front end being a touch higher after the swap you are spot on, you now have more weight behind the xmember than before so its gonna lift a bit, i noticed that too when i did my rb20 swap into my s14, works a treat and improves handling a bit.
Edited by carl h
what a piece of shit. doesnt look like a 31 at all. still a girls car you shirt lifter.
RB30e is a sweet motor though, definatley the best thing about the car (well the bonnet scoop is pretty good too). So refined and powerfull and it just looks so sexy sitting there. hopefully it will chirp the odd second too.
go bananaman.
banaman has been nothing but trouble for you pete. he is a bad influence no doubt about it. ever since he rode into town in his 31 wagon things have gone downhill.
Fatz, you are my hero... keep up the good work, im hanging out to see some updates on power delivery/traction/handling when its all sorted, just be sure to go to a sperm bank and save some 'genetic material, cos I think your lovely girl will probably relieve you of your balls, and I want to clone you :D
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
