I just did a quick search, but didn't see anything relevant - How do you guys reckon a Discopotato(GT2860R i think) would go on an RB20? too laggy?
Just considering some new turbo options for the 20 and a few mates suggested this..
EDIT* This is for a heavily drift orientated setup by the way..
Edited by Josh
https://www.sau.com.au/forums/topic/114030-discopotato-on-an-rb20/
on SR's the disco is not too laggy, doesn't have huge top end power, but is pretty grunty down lower...
what would make it work differently on an RB20? Im no expert but would it have something to do with the different exhaust pulses(and volume of gas in each pulse) of the SR and RB's?(Considering they are the same displacement, just 2 more cylinders..)
shouldnt be to laggy at all..
on a rb20 you would get about 220rwkw with it
but with it you will also need a new dump pipe, water and oil lines, and t28- t3 adapter flange + labour
in the end better off getting a GCG highflow for the same power and less hassel straight bolt on
Mmm, not gunna worry about a highflow.. I do realise I will need the flange adapter, oil + water lines, but just considering something different..
However talking to a fella I know, he reckons it should go alright, but will be fairly laggy. Won't go as well as it does on an SR due to RB not having the dynamic torque that the SR's have..
The Discopotato GT28RS AKA GT2860RS is really a slight compressor variation on the HKS GT2530 but its housings suit 4 pot 1800-2000cc better . It tends to like being used in .86AR (GT28) exhaust housing and the TO4B compressor cover is fitted because it can turn some big revs and pump a lot of air for a 60mm compressor . I do remember someone fitting it in this form to an RB20 and found it laggy - sort of the all in with a bang at 4000rpm . If you were lucky and had the HKS T3 flanged 2530 exhaust housing (.64AR) it would no doubt pull the bottom end up but then its not operating as its designer intended so no promises .
I don't have time to get into an SR20/RB20 debate but it is obvious that the RB20 was designed to rev where the SR20 was not . The whole 4 cyl/6cyl thing is going to revolve around individual cylinder capacity and breathing so they really are worlds apart . For convienence sake I reckon DP for SR20 and either Hi Flow or model specific 2530 for RB20 . Because I'm obstinate I would build (get built) a variation of the real GT3071R with the slightly smaller 52T compressor so that it would not have high boost anywhere but a broad power range to roam around in . It would have to hang off the HKS manifold and be externally gated so not cheap easy or convienent .
Cheers A .
discopotato (GT28RS) is less laggy than GT2871R
here are the specs for people who are intersted
GT28RS
HP 350
Compressor 60mm A/R .60 Trim 62
Turbine 53.85 AR .86 Trim 76
GT2871R
HP 400
Compressor 71mm A/R .60 Trim 56
Turbine 53.85mm AR .64 Trim 76
(2 versions of gt2871r one has .64 A/R on turbine, one has .86 A/R on turbine, all other specs are the same)
Another thing we were possibly thinking about was getting an RB25 rear housing machined to fit the disco.. that way its a straight bolt to manifold jobby not to mention retaining the same dump..
all in by 4000 doesn't seem too bad either..
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
