Based on my experience, having to use 2nd gear on the dyno in an auto always makes the boost look spikey. You really need to use engine rpm instead of road speed when dynoing an auto. That at least removes the torque converter slip from the equation. The same set up in a manual in 4th gear would give a 1 psi spike which no one would be concerned about.
My suggestions would be;
1. Turn up the boost, that turbo has plenty left in it. Around 22 psi is more like it. You have the bottom end to use it.
2. If you are still getting a 3 psi boost spike at 22 psi I would be looking for another boost controller. We use the PFC Boost Control Kit with plenty of success.
3. A set of 256 Tomei Poncams would be next on my list. An adjustable exhaust camshaft pulley is not necessary, based on our experience the Poncams are timed perfectly out of the box.
That and the extra boost should see you comfortably over 300 rwkw.
:laugh: Cheers :D
  • Replies 40
it could be a mechical auto box (VLT style) or it could be the stock box and he doesn't care about the changability of the gears and smoothness. It's covered quite cleary in the FAQ re: PowerFC and auto
yea yea.. bla bla..
just because the faq sheet says bla bla..
not being a nasty..
but i have never heard you say that you have actually been in a auto 33 with
a power fc in it.
have you?
the standard 33 trans drives exactly the same as it did with the standard ecu.
anyone that owns a auto 33 im more then happy to prove it works perfectly..
but i bet you cant prove that it dosent work....
obviously over 300 kws the trans will eventually need a rebuild with stronger clutches etc
but for $2500 for the full works and jerks racing trans upgrade including high stall converter
yes you are correct i have never been in an auto r33. but thats not the point. the point is the nissans have code for the auto box in the ECU and the powerfc does not have any autologic present so it wont back off timing on gearchanges. this would have to results in different operation to that of standard
i think my plumb back, blitz bov was also bypassing at high boost so i have replaced it with another one
i had laying around, and i was able to drop the ebc duty cycle down 15 % and still make the same boost.
may have had something to do with it.
im heading back to the dyno in about an hour so i will try again with the new bov and see if it levels the boost out a bit.
1.5 bar ya reckon Gary..
that will get my missus to the shops in a real hurry... :laugh:
i just got back from the dyno..
as you can see from 18 psi to 23 psi it dosent make much more power.
is this due to the ehaust housing being to small.
the leaking bov that i fixed earlier today helped but didnt solve the problem.
im now making the same power today with the ebc set at 18psi then i was making
yesterday with it set at 21 psi..
should i get the ehaust housing machined out a bit to slow the compressor wheel down and increase flow?
What spec exactly is the turbo?
thats going to help a lot so the turbo tech people can get into it and see what the front and the rear are doing :D
the GCG tag states GT3071R-SP
the Garret tag states GT2835R - 56T
700382-20
its a single turbo 300zx ehaust housing with internal gate
made into the above specs.
i hope this helps
ive seen people run autos on the dyno in D with overdrive off (so basically 3rd gear).
Anyway well done on power level. Have you taken to the drag strip?
not as yet...
adelaide international raceway is in all sorts of trouble at the moment.
i think the next street meet isnt until sep or oct
I've read of other people installing GT3071Rs (in the US) on their cars, and talk about them having an anti-surge compressor cover?! I could be completely wrong, but that compressor cover isn't, is it??
For risk of sounding "ricey" but does this turbo have a particularly "whistly" induction noise when it comes on boost?
ahh not really
it sucks like a pig thru the k&n pod filter but i wouldnt say it wistles
Are there any side affects from using the power fc on an auto??many people say they dont run like factory e.g wont kick down gears etc etc, ive been looking around at engine management for a while (i have a r32 gtst auto) and have read that "no" aftermarket ecu (including the greddy e-manage & e-manage ultimate) can cope with the factory auto ecu as it cuts ignition timing when changing gears!so my only real option is chipping the ecu or getting a safc, which im not really to keen on using!Yours is the only auto ive heard of using a power fc without any problems so some help would be much a appreciated, cheers :P
Edited by nizmo_freek
Are there any side affects from using the power fc on an auto??many people say they dont run like factory e.g wont kick down gears etc etc, ive been looking around at engine management for a while (i have a r32 gtst auto) and have read that "no" aftermarket ecu (including the greddy e-manage & e-manage ultimate) can cope with the factory auto ecu as it cuts ignition timing when changing gears!so my only real option is chipping the ecu or getting a safc, which im not really to keen on using! so some help would be much a appreciated, cheers :P
"Yours is the only auto ive heard of using a power fc without any problems"
have you heard of someone trying it and it didnt work?
there a lot of people in the world that fill everyones head with bullshit!
but they all drive manuals.
i dont own a 32 auto so i cant comment, but the 33 auto works exactly the same as
it did before i changed ecu.
at the end of the day what have you got to loose.
buy one plug it in, if it works fine then get it tuned and enjoy.
if it dosent work put it back in the box and sell it as brand new.
and get your money back..
there are heaps of guys on here that will buy it from you.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
