This is the internet...a quick "google" of performance ceramic coatings will give you hundreds of examples of where this product has been tested and proven. Like i said before, your example does not mean or prove anything if no before/after comparison is done (this is how i do my testing). Like Silv.is trying to explain and i have also stated earlier in this thread, the coating is done on the turbine side to aid gas flow....not too keep things cool around it, thats the job of heat shields etc.
Thanks for the acknowledgement of our work...its good to see the time, effort and dollars paying off
The coating claims to work by keeping the surface of the pipework cool, ie keeping the heat within the piping. (actually the second site simply claims it is a 'thermal barrier')
http://hpcoatings.com/products/heat.aspx#E
http://www.performancecoatings.com/
If you acknowledge it has little effect on the amount of heat radiated from the pipe/exh housing (in contradiction to how it is 'meant' to work) then what do you think it actually does? I am not arguing that keeping heat within the exhaust improves performance, thats a given, im just trying to determine what you think it does. As i've said, if the coating does not decrease the surface temperature of the coated item then it is not effective. (The image I attached shows the surface temp is high in the coated region and at the same time clearly radiating a significant amount of heat as the subsequent uncoated region is comparatively extremely cool- it shows the thermal gradient is not affected by the coating.)
Actually I have googled (and had a quick look on a few engineering databases) and havent found any technical information in support of the coatings, but alot to the contrary actually.
  • Replies 179
Are you not able to understand the written word??
Go back and "properly" read this thread....i think ive made myself clear in no uncertain terms what i think it does, the performance benefits of it and the application ive used it for.
As for contradiction (seems to be your favorite word) go back and read your last post...you make no sense and are starting to get lost in your own babble.
As i said previous...I think you need to start you own thread...you seem very passionate about it
Not passionate, just bored.
I've read the thread and your comments, the word 'contradiction' comes up in my posts alot as that is what people are doing when talking about these coatings. I thought my posts were quite clear?
I will leave this here, if you wish to discuss further we can take it to PM rather than draggin your thread off-topic
All the best in your chase for 9's
Hard luck paul & stace. Now just have to wait and see how they perform on the strip.
I'd be looking forward to hear your impressions of the gtrs's, their spool repsonse mainly.
It'll be about 6 months beofre i'll be able to fire up the R, but then we'll have some stats of how the gtrs's run with a 3ltr bottom end
All the best for tomorrow!
No hard luck...just a little surprised at the lack of improvement.....but.....this is only what the dyno says.
The real improvement we want to see most is trackside.
Stay tuned....tomorrow the real test begins.
At least say "courtesy of tommo" when using MY photo :O
I'll be there tomorrow taking photos as well
Yeah...pretty rude eh TommO...not only does he use unauthorised material....but....its not even a picture of him at the wheel....lol
Make sure you come and say g'day mate.
The only time I saw it run was in the afternoon, and it didnt look overly happy and was towed back... rumor has it a newish N1 oil pump took its bat and ball and went home?
Good to finally see some GTR's out though, I was in the cheer squad for JUN... not bad for its first run, and the thing sounds mean :D
Edited by Amaru
I am dissapointed, as I know you are. But I am not really all that surprised. I truly believe that you had the ideal engine configuration for 2530's. The dyno and track results certainly confirm that.
On the other hand, the results I have seen from GTRS's are patchy, sometimes they work and sometimes they don't. The only consistent good news seems to come from engines with capacities more than 2.6 litres.
Maybe the alternative (from a 2.6 litre) is higher RPM, but that is hell on components.
Good luck, I sure hope you get those GTRS's to work for you.
:D cheers :D
Bigger cams needed apply within!
Yep, then bigger valve springs, lighter retainers, more durable valves, higher valve train wear and stronger rods needed (if I remember rightly). Then maybe lower diff ratio, higher rpm launch, drive train wear etc etc. Higher and higher rpm is a vicious spiral, the secret is to know when to get off.
:D cheers :D
:no: cheers :)
Yeah SK your dead right mate. The 2530/cams/displacement setup was perfect......tried to launch the car the same as the 2530's and bogged badly off the line. Back at the pits we decided that a 9000rpm off the limiter launch (previously was only 8250) was needed and bang oil pump drive collar is now in two pieces.
Ouch, I read that in the Compact thread. Engine damage?
:no: cheers :)
:) cheers :rolleyes:
Unknown yet, but we run an autometer warning light and a 30psi hobbs switch to monitor pressure. It was an immediate shutdown, but as you know these things are hard to catch. This engine is over 2 and a half years old and was starting to breathe a little heavy and make "interesting" noises on the dyno in the last 6 months, so it was planned to strip it and freshen it up soon.
Tossing up either using a JUN pump or going external single stage dry sump pump scavenging from rear of sump feeding the oil filter at the relocator block...what do ya think??
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
