I have some adjustable whiteline swaybars for my R32 and i'm just looking for some recommended settings for my car, hard/medium/soft?
the car is a weekender that spends most of its time in the hills and will sometimes see the track for drift and grip racing!
I was thinking medium/hard for the rear and medium/soft for the front!
Can people with experiences in this field please give me their input!
cheers in advance!
https://www.sau.com.au/forums/topic/115002-whiteline-swaybar-settings/
hey iam fitting mine up next week ill let you no how they feel, ill be setting the rear hard and front medium....just dont set the front to hard or youll be understering!
i'd heard not to set it too hard at the front, for that reason i was going to go soft. let me know how you go!
Ditto this is so much a personal preference thing, and a sum of the other mods you have.
As for setting the front to hard causing understeer, ill enter my car into evidence as exhibit A for not understeering...and R32_bigboy as exhibit 2 as he now has my swaybars and we set them to hard both front and rear and it handles nicely....so?!?!?!
mmmmm
i'm thinking i may set both to medium to start with and go from there!
mmmmm
I have both my sway bars set at medium.
I first installed these as the only mod to the standard suspension, and noticed a massive improvement - with very little under steer.
I have since installed everything else in Sydneykids package of goodies, and made another step forward in the cars handling. However, now at the limit, it tends to under steer a little. As such I am now considering stiffening up the front sway bar to hard, to dial this out. Thoughts?
Edited by Ryno
I have since installed everything else in Sydneykids package of goodies, and made another set forward in the cars handling. However, now at the limit, it tends to under steer a little. As such I am now considering stiffening up the front sway bar to hard, to dial this out. Thoughts?
First thought is that you have it upside down, Miss Jane.
If you want less understeer soften the front bar (or stiffen the rear). Increasing roll stiffness with anti roll bars will (all other things being equal) degrade the grip at whichever end of the car you make the adjustment. Which is why you start tuning with the bars on soft and then stiffen things up at one end to balance the car out.
Personally I adjust the opposite end to that with a problem. For example, to lessen the understeer I stiffen up the rear anti roll bar. If the rear bar is at full hard and I still have understeer, then I soften the front.
:D cheers :nyaanyaa:
:( cheers :D
Sweet, stiffening the rear it is.
There are a couple of things to note:
1: In steady state cornering anti roll bars kill grip! An ugly truth, but there it is. They work by transferring load from the unloaded side of the car to the loaded side. Note that after a point the friction coefficient for a tyre falls away the more heavily loaded it is. (This is ignores temperature effects)
2: It may well be worth comparing the cars grip levels with the front soft/rear at medium with the front on medium/rear on hard. Remember balance and grip are two different things. Try it see if you can find which you prefer. (This all assumes one level of adjustment is sufficient)
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
