  • Replies 78
Dinner has been booked for Sat night (Look out Shepparton)!!!
All the above accommodation info will be on the WRX forums tomorrow so anyone who has not booked - better get to it.
Also - people with cabins - if you have spare beds you want to get rid of - post it here, Im sure someone will need one.
Cheers all.
PS. Check 1st post for what has been booked and what is still available.
5. This thread was to enable people to pre-book accommodation. If you enter the event (entries open early May) then you can suss out accommodation then.
Damn freaked me out there! Couldn't find an event thread and saw this accom one and thought that dirty kent snowy....he needs a brick thru the window!
He's safe for now it seems :)
1 double & 1 sofa couch - 2 booked / 0 reserved - Justine (16) & LetMeDrive_Scott (17)
for two people = approx $90/night, plus $10/extra person/night
do we have any idea of how many of these are actually available at the place?
I don't want to book 1 yet as i don't know if the mrs is coming....
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
