  • Replies 52
You ricer Roy! :) Going for the 'sound' rather than anything else! :ermm:
If anything i crave the RB smoothness. Sounds and feels cool but after a while I get sick of it, like a atmo BOV if you know what I mean.
Was thinking, u want a rough idle, just lean her out a bit to the point where it starts missing at idle load points. Then you get the shakes and misfires and general farting around that you're craving for lol.
Oh yeah 9krpm's 272s sounded pretty damn tough on idle. Probably too rough for a street car I'd say though.
You make me laugh :bunny:
The only time i've heard an angry RB is when there are some large cams being used like in Daves car... and the old Jet33... Jacks car has a very slight difference but not major
They werent 260/8.5 though :O
Jacks car sounds awsome, but not too cammy. Has a slight lump. The 280's i have on my car though. Fark that sounded angry. Oh the memories :)
There's some really good ideas in this thread. Have you tried feeding your engine banana's instead of 98?
Aiiee, the good ol' banana in the tailpipe.... although I've heard that since moving to Melbourne Troy's been getting a bit of the banana in the tailpipe... and enjoying it! :(
I have HKS 264s in my R33 GTS-T and have a mild lumpy idle, and yes making leaner will make it sound lumpier.. I made mine a little richer as neighbours were complaining about exhaust noise.. but will change back when I get my quieter twin system ;-)
Good midrange too...
Edited by Color_Of_Green
options as i see it:
- some expensive, but high-lift cams
- ej20 conversion
- wire up a switch to cylinder #1 and kill the spark when at idle
- record the noise of a 427ci engine and put it on CD and play it while driving
- make the noise yourself when driving and convince your passengers you're not crazy
hope you find a solution :)
Warren.
Aiiee, the good ol' banana in the tailpipe.... although I've heard that since moving to Melbourne Troy's been getting a bit of the banana in the tailpipe... and enjoying it! :D
...well how else am i to get this money togther for the "GTST of extraordinary magintude"
And thanks for all the informed responses hillbillies :ermm:
mate, you will find even the 260/260 poncams can give a quite lumpy idle. it's in how it's tuned and how the cams are dialled in. even my GTR with stock cams but adjustale gears has a bit of 'funk' to it at idle. Nicks GTR with poncams and cam gears is very lumpy at idle.
troy the count is on your side. a nice lumpy idle is the go. do it.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
