  • Replies 234
Posted Images
Wink: Yes
Richard: I've learn from the past to not take a half assed car onto the track, it only results in broken bits. I still need to get:
Braided brake lines
Decent pads
Semi-slick tyres
Splitfire Coils
Catch Can
Sump Baffles
..atleast before you will see me on a track.
Edited by benm
Wink: Yes
Braided brake lines
Decent pads
Semi-slick tyres
Splitfire Coils
Catch Can
Sump Baffles
deadset you dont need any of that sh1t. dont get me wrong it's all nice to have but for someone that loves motorsport (and i know you do) dont let the track days pass you by!
the only thing on that list i reckon is really neccesary is decent pads. under $400 will get you a full front and rear set.
sump baffles is a concern but man it will cost you prob around $1K just in labour to fit them. I've got a set of tomei ones in my bedroom and so far they have controlled my oil surge very well from there. People say, do you have sump baffles, i answer 'yes'. problem solved :D
Top Day first Aaron McGill day I have done and tops fun the littel race at end of the day. Nathan from Grey Imports is a good driver and was hardest by far to past as he made his car very wide. Hope to hook up with Aaron M for future days.
PS Always check brake pads prior to the day.
Yeah i was a bit worried in the last race about your 300 catching up to me.... luckily it was only a 8 lap race and i had a HUGE headstart.
Afterwards Nathan said he did a good job of keeping his car as wide as possible for you John :D
oooooooooooook vid is here
very basic recording with completely seteady shost of the straight 4th corner and a few other bits but i think most cars are on there towards the end of the day
quality is pretty good
http://rapidshare.de/files/21858485/Oran_P...-05-06.wmv.html
i made it this way so its good for editing
WTF!!?? I can access it saying denied P2P....AAARGGGHHHHH
Ill put it on a disc for you bish
I have to head over to the inner west today - ill leave it in your bucket of bolts :mellow: - is it still with Nathan?
problems with power out of the right handers is most likely fuel surge (did you have less that 1/2 tank?). it's quite common. the only easy fix is put more fuel in the tank!
Yeah .. when i came back from lunch after the top up it stopped. But when the tank went to half it came back again..
So is there anything i could do other than top up fuel??
well the only proper way to fix it is with a surge tank (really anti-surge lol). Basically you can run your standard pump feeding the surge tank, with a new high flow pump taking it's feed from the bottom of the surge tank.
Woah that was a quick reply .. haha.
Think i will just stick to topping up the fuel. The surge tank sounds exp.
Anyway, tks
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
