Why dont we do a movies night, Cruise to dinner then cruise to the movies watch and cruise somewhere else after to talk about the movies HAHA the only reason I say this is because simpsons are on and I have yet to see it :action-smiley-069:
Ideas for next cruise:
1. Don't make meetpoints so close to residential areas, otherwise you'll only have 10mins MAX before police arrive.
2. Longer legs, keeping a cruise within one or two police districts (eg. all NOR) is not only boring, but also attracts attention.
3. Metro area cruises are all but dead, some hills/out of the way roads are required for the early legs.
4. If the cruise is going to be big, keep away from low-speed single lane roads.
Just some suggestions...
5. Start in outer suburbs so the cruise doesn't get split up so much by traffic lights?
because it would be a 4 hour round trip just getting to Bunbury and back! Plus and extra 2 hours for them to show us where they drive... 6 hour cruise? May as well fly to Melbourne
that sounds good...or you could get a cruise going to drive here...and then join the great ocean road cruise :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
