Alot like how only one of your air conditioning functions works :)
only because i accidently pulled it out trying to get heat on while i was driving on a bumpy rd in busselton hmmm
WGMG? Bunbury roads, they are shite!
WRGMG: Public transport, when people in front of you walk hell slow down the stairs and your train is about to leave.
also to a larger extent, the Australian Government a bunch of dickheaded thieves
taxi drivers who stop on busy roads when there is a perfectly good side street or driveway,
taxi drivers who are pulled over in a fkn stupid spot then when its clear to overtake they pull out into u.. then they do 15k's under the speed limit so u overtake them and they swerve at u on ur way past.
taxi drivers in general,
is it me or everyones washer jets seem to have problems?
mine just stopped working and i cant work out why :down:
WGMG are tossa's who pull into the gap you leave between yourself and the car in front..... and to the tossa in the 32, that gap was not for you dickhead!!
I really hate this, especially when youre going down the freeway and ESPECIALLY when its raining.
WGMG, stupid mums in 4WDs late picking up their kids and haaave to floor it to get 1 car infront when lanes merge! :blink:
merges are just overall shite here.
i saw someone get to a merge on leach hwy the other night, and they braked...there werent even any cars around them...(i was behind)
but yeah
crazy people in over sized cars that werent even built for the city :blink:
eff off.
Engineer's who come from another country, can't speak the language and have no experience in the job. Then when they find something that they think isnt right but is then give you a tune about it. Grrr! :D
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
